Forscan balancing and battery data
Old Nov 6, 2023 | 03:19 AM
Default Re: Forscan balancing and battery data
Originally Posted by PTTech
Thanks again for your help. Starting to sound like the battery... Is there anything to trying to replace bad cells? I mean is it a good idea or worthwhile? I'm pretty crafty, but ignorant about this stuff. What's involved in doing a grid charge?
You would need to disassemble the pack and individually test 50 5 cell sticks for capacity, internal resistance and self discharge.
This thread describes building a charger to replace the jump starter removed from 09+ models:
https://electricvehicleforums.com/fo...ry-jump-31056/
It can be also used to grid charge if you provide an external cooling source. I've done it many times by removing the battery cover and laying a box fan on top of the battery to blow air down through the cells. 24 hours of charging is needed.
GatorJ
Jul 15, 2022 05:38 AM
fglaustin
Feb 27, 2021 06:11 AM
econoline
Feb 8, 2018 06:06 AM
Scottzzzz
Mar 1, 2017 08:33 AM
hsolo142
Toyota Highlander Hybrid
16
May 25, 2006 10:59 PM
