FEH '09 Cabin Air Filter
Old Aug 5, 2008 | 06:17 AM
TeeSter's Avatar
Default Re: FEH '09 Cabin Air Filter
Originally Posted by way2muchkc4u
Took a look and even removed the three "screws." I CAREFULLY lifted the plastic, with the 09 it's all one piece, still attached to the rest of the car. Underneath the left side, I can see a wire mesh. I would not call it a filter at all.
So looks like you're right. Ford deleted it all together???
PS I can already see bugs on it..... can't wait to see it @ 50,000 miles!
On the '06 there is no filter installed from the factory. It fits in a space over top of a plastic "mesh". I can't look at yours but that mesh isn't the filter... but is there room for one on top of it?
Old Aug 5, 2008 | 06:52 AM
MyPart's Avatar
I don't think that Ford has ever included an actual cabin air filter on the FEH. Just the location and the option to purchase one after the fact.
I used the Motorcraft FP-66 (8L8Z-19N619-B) on my '08 FEH. The AC Delco CF108 (89031230) will not work but I believe it works for the '05-'07s.
Last edited by MyPart; Aug 5, 2008 at 10:31 AM. Reason: I had the product numbers reversed
Old Aug 5, 2008 | 09:24 AM
way2muchkc4u's Avatar
Cool Re: FEH '09 Cabin Air Filter
I used the AC Delco CF108 (89031230) on my '08 FEH. The Motorcraft FP-66 (8L8Z-19N619-B) will not work but I believe it works for the '05-'07s.
Thanks again guys for all the info.... I was awaire that Ford did not include the cabin air filter.... I was not awaire that they stoped making it "easy" for the lamer to put in place. As it stands I'm looking to buy the filter and try it. The filter is listed as FP-66 in the manual... hummm I'll double check that..
Like some of you I really just want to keep the cabin cleaner and maybe my nose too.... maybe
Old Aug 5, 2008 | 10:35 AM
MyPart's Avatar
SORRY . I had the numbers reversed in my original post (corrected now). The FP-66 DOES fit the '08 FEH. The AC Delco CF108 DOES NOT.
wbonville
Oct 1, 2010 07:06 AM
dgyimao
Dec 31, 2009 09:38 AM
sanosteam
Dec 26, 2009 07:17 AM
EOppie
Jun 30, 2009 08:08 AM
bugs
May 26, 2009 12:05 AM
