Coolant temp
Old Oct 17, 2007 | 08:30 AM
fm606713's Avatar
Default Re: Coolant temp
Originally Posted by GaryG
If you turn your climate control to the off position in EV, the electric coolant pump remains off and will not circulate coolant. This will help keep the engine warm till you get a restart. When the engine starts, the belt driven pump will start circulating coolant again. The reason you have an electrical coolant pump is for use of the heater in EV. The electric pump will run in EV unless the switch is in any position but off.
GaryG
This explains why the coolant temp decreases as quick as it does when in EV mode and I am running the heater here in Colo.
Old Oct 17, 2007 | 04:24 PM
Mark E Smith's Avatar
Omnia Gloria Fugit
Gary thanks that did the trick. Coolant temps are somewhat steady with the vent off. they are still low in my opinion but seem to track what most are seeing. I remember you posting something about not running your vent system that it cost you FE, I thought you were nuts, but now I see what you mean. I'm gona see if I can disable the heater pump, after all this is Texas.
robbiedoo
Jan 4, 2013 04:41 PM
Droid13
Jun 18, 2006 06:38 PM
mg48
Dec 1, 2005 05:04 PM
laurie
Nov 22, 2005 11:56 AM
Dale B
Apr 10, 2005 10:03 AM
