A/C Shut Off
Old Jun 26, 2005 | 07:15 PM
AZMerf's Avatar
Default A/C Shut Off
Does the A/C shut off when the vehicle is at a stop light like the original Pirus? The HCH does this if you have the economy mode engaged. Just curious.
Old Jun 26, 2005 | 07:22 PM
sweetbeet's Avatar
Happy Hybrid Owner
Default Re: A/C Shut Off
In the '05 FEH, if it's set to "AC" or "AC with recirc", then the AC shuts off whenever the ICE is not running (which usually happens at stoplights, after the initial warmup period, and other times as well). If it is set to "Max AC", then the AC overrides the ICE shutoff, and the ICE keeps running all the time to provide cooling.
Old Jun 27, 2005 | 10:24 AM
Pravus Prime's Avatar
Prof. of Hybridology
That's the same in the '06. AC and AC recycling are off when the ICE is off. AC Max, ICE never goes off, Max AC stays on.
There are settings that are red in the FEH, that indicate that the ICE will be on regardless of charge or circumstances that would otherwise turn it off; Max AC and Defroster.
Maxi3D
Sep 25, 2012 11:19 PM
AlmostInsight
Jun 16, 2009 02:43 AM
UMHB-Hybrid
Apr 3, 2006 10:32 AM
sweetbeet
Nov 2, 2005 12:07 PM
