Brake pad choice
Old Oct 5, 2020 | 06:27 PM
giro97's Avatar
Default Brake pad choice
Good evening everyone! I need to change my brake pads and rotors since they are pitted and are starting to make noise.
I was looking at pads and rotors on rock auto and I noticed that some motorcraft ones have an option for regenerative braking and some don’t. Rockauto shows that both will fit and work fine.
Do you think that they are different? I was looking at maybe using the Powerstop brand ones, but they do not mention anything about regenerative braking.
thank you
Old Oct 6, 2020 | 06:00 AM
Hippo the Hybrid's Avatar
Default Re: Brake pad choice
There was an earlier post discussing this issue. Personally I would go with OE designed for regenerative. They have passed the test of time and are not expensive. I would also replace any related hardware like clips etc which you may have to buy separately especially if you are in the salt belt. .https://www.greenhybrid.com/forums/f...010-feh-32397/
Old Oct 6, 2020 | 06:35 AM
Rex B's Avatar
If you want to maximize the benefit, consider rebuilding the calipers. The seals function as a "spring" to retract the pads slightly to pull them away from the rotors and reduce friction when it is not needed. Over time and many heat cycles the seals lose their flexibility and no longer retract the piston as designed.
This is quite a bit more trouble as you have to go through the complicated bleeding procedure.
whatawuss
Apr 7, 2017 05:40 AM
Yoon395
Aug 30, 2012 01:52 PM
ManyMPG
Honda Insight
Jun 20, 2011 07:11 PM
Doug121041
Sep 29, 2010 07:53 PM
schmidtj
Jun 3, 2007 07:49 AM
