AWD system on FEH?
Old Aug 1, 2006 | 04:48 PM
econoline's Avatar
Default Re: AWD system on FEH?
Originally Posted by ElectronBob
The diffs are all open. Power to the rear wheels is controlled by a set of clutches in front of the rear diff. The max torque that can be sent to the rear wheels is 50%.
I've got a followup question on this. With an "open" differential, does that mean that if one wheel on a given axle is losing traction (spinning), then more torque is directed to the spinning wheel instead of the wheel that does have traction?
Does the AWD FEH have a system that applies the brake to the spinning wheel (using ABS) to force torque to the other wheel? I know that some AWD vehicles use this system to simulate a limited slip differential using the computer instead of clutches in the diff.
Old Aug 1, 2006 | 05:09 PM
TeeSter's Avatar
If you are referring to one of the computerized traction control systems the answer is that the FEH does not have one at this time as I understand it.
Old Aug 2, 2006 | 04:52 AM
WaltPA's Avatar
Yes, and I learned that the hard way with my first Jeep. I was trying to save a few bucks, and did not order the limited-slip differentials. Later, in snow/ice, I got stuck with one wheel spinning and the other three just sitting there. Boy, it is embarrassing to be stuck like that in a Jeep. From then on, I always ordered the limited-slip differential option on all 4x4's.
Well, I guess until now.
Old Aug 2, 2006 | 04:58 AM
TeeSter's Avatar
What I'm referring to is electronic stability control. Its designed to prevent rollovers. I don't think its what you are talking about.
Sazghool
May 29, 2015 10:27 AM
diver110
Feb 18, 2011 09:04 AM
bostondick
Introductions
Feb 15, 2006 05:55 PM
Muhman
Introductions
Dec 20, 2005 03:13 PM
ChadsMach1
Nov 20, 2005 04:54 PM
