An ACCURATE ScanGuage Fuel % correction...
Old Jun 17, 2008 | 07:35 AM
TeeSter's Avatar
Default Re: An ACCURATE ScanGuage Fuel % correction...
Originally Posted by MyPart
I can tell you that I use the exact same pump and fill until I can see a little gas (splash) coming out the filler neck. I park in the same direction/spot at the pump and also shake the car and fill slowly to reduce air pockets in the tank. I'm pretty sure I get a near consistent fill level every time.
That said, my NAV has almost always been off by 1-2MPG when compared to hand calculations.
I don't have a Scanguage...yet.
Like I said its possible I've got a NAV that is spot on and got lucky. Didn't mean to accuse anyone of anything just wanted to point out that using one tank could give one erroneous results. I averaged over several tanks to determine my % and thats much more accurate than using one tank like the SG manual states.
Also... you probably know this but remember that if you are using full tanks as a comparison for MPG on tank/NAV that the NAV ONLY holds a certain amount of data. I put only 40 miles on mine and presumably the data buffer is long enough for that.... so it matches. But by the time the tank empties the buffer will have filled up, overflowed, and all the "early" data is lost and the NAV is only reporting the MPG for the END of the tank of gas, not the whole thing. Admitedly that would presuppose that if you are always 1-2MPG high then you'd always be getting higher MPG from the END of a tank than the start... I suppose it could be the weight of the fuel that would cause that but on a 4,000lb vehicle that seems supect.
As for the data buffer effect..thats what is believed to be the case here on GreenHybrid from the evidence thats been presented.. that the NAV has a limited buffer of data its working with and a running average, not all the data from the last reset.
Theres no reason it HAS to be that way but someone at Ford decided a running average of the latest data was more useful than the average since the last reset. Go figure.
Old Jun 17, 2008 | 01:21 PM
MyPart's Avatar
Didn't mean my post to come off as a post-accusatory reply. I was simply making the statement that I've gotten a pretty consistent variance while trying to keep the pump and fill level constant.
Maybe I (and my wife) are subconsciously driving more conservatively at the end of the tank knowing the unpleasantness that is soon to follow...
Old Jun 17, 2008 | 01:56 PM
TeeSter's Avatar
Didn't want mine to be accusatory either... just posting observations. No harm done.
Billyk
Jun 30, 2009 03:50 PM
Billyk
May 8, 2009 06:55 PM
Billyk
Alternative Fuel Vehicles
Nov 27, 2008 07:28 PM
ibubbles
May 20, 2008 08:53 PM
Mr. Kite
Toyota Highlander Hybrid
13
Jun 19, 2007 12:47 PM
