2008 Ford Escape Hybrid Stereo Wiring Diagram
Old Sep 11, 2018 | 09:43 PM
accent2010's Avatar
Default 2008 Ford Escape Hybrid Stereo Wiring Diagram
Found a non-hybrid version but it is very different with hybrid. Hybrid's Black/Gray is ground while non-hybrid's Black/Gray is 12v+
Anyone has the diagram for hybrid?
Old Sep 12, 2018 | 02:59 AM
btarb24's Avatar
2006 & 2007 FEH
Default Re: 2008 Ford Escape Hybrid Stereo Wiring Diagram
I checked a 2006 service manual I have and it doesn't show anything with grey at all. Perhaps they changed colors on the 08. Though, just to double-check.. are you looking at the original Ford wires or are you looking at the wires coming from an aftermarket adapter that's plugged into the ford connector?
If you let me know which pin you're curious about then I can look up what that circuit is. Though, most diagrams are unlikely to show you the polarity, rather, they usually only tell you its purpose.
Old Sep 24, 2018 | 10:26 PM
accent2010's Avatar
I tested all the stereo wires but found no +12V ACC. I guess ford used a +5V as the factury stereo's ACC. I had to wire a +12V ACC from fuse box to my new stereo.
Old Sep 28, 2018 | 12:05 PM
Rapheal's Avatar
Do you mind taking a picture and showing where you did this? I have a need also.
Old Sep 28, 2018 | 02:14 PM
btarb24's Avatar
2006 & 2007 FEH
Does the cigarette lighter deenergize when you turn off the car? If so, then you could use that as your 12 V ACC line since it's nice and close.
Old Sep 28, 2018 | 02:56 PM
elborak's Avatar
Cheapskate
My 2006 had a switched 12V outlet in the front, but my 2009 has constant power. Not sure whether that difference came with the 2008 "cosmetic" changes or the 2009 update.
Old Sep 28, 2018 | 07:46 PM
accent2010's Avatar
no, the 12v lighter on 08 and after are always hot. ford calls it a feature. i like the cars in the old days though.
Old Sep 28, 2018 | 07:54 PM
accent2010's Avatar
I wish I took a photo before I sold it but it's not too hard to locate the fuse with a multi-meter. Install the backup camera is difficult though. I'd not work on such kind of projects again.
Old Nov 8, 2019 | 06:00 PM
accent2010's Avatar
I used the #43. Later I found #44 is better but I'm too lazy to change it.
rmpowell2001
Oct 25, 2019 10:46 PM
tayseer2006
Jan 2, 2015 05:41 AM
jgenb
Nov 8, 2014 07:19 PM
raypou
Jun 23, 2005 09:00 PM
