2008 Ford Escape Hybrid Stereo Wiring Diagram
Found a non-hybrid version but it is very different with hybrid. Hybrid's Black/Gray is ground while non-hybrid's Black/Gray is 12v+
Anyone has the diagram for hybrid? |
Re: 2008 Ford Escape Hybrid Stereo Wiring Diagram
I checked a 2006 service manual I have and it doesn't show anything with grey at all. Perhaps they changed colors on the 08. Though, just to double-check.. are you looking at the original Ford wires or are you looking at the wires coming from an aftermarket adapter that's plugged into the ford connector?
If you let me know which pin you're curious about then I can look up what that circuit is. Though, most diagrams are unlikely to show you the polarity, rather, they usually only tell you its purpose. https://cimg4.ibsrv.net/gimg/www.gre...1d699cb39b.png |
I tested all the stereo wires but found no +12V ACC. I guess ford used a +5V as the factury stereo's ACC. I had to wire a +12V ACC from fuse box to my new stereo.
Originally Posted by accent2010
(Post 266467)
Does the cigarette lighter deenergize when you turn off the car? If so, then you could use that as your 12 V ACC line since it's nice and close.
My 2006 had a switched 12V outlet in the front, but my 2009 has constant power. Not sure whether that difference came with the 2008 "cosmetic" changes or the 2009 update.
Originally Posted by btarb24
(Post 266478)
Originally Posted by Rapheal
(Post 266476)
Do you mind taking a picture and showing where you did this? I have a need also.
(Post 266476)
https://cimg3.ibsrv.net/gimg/www.gre...ae1d140c2d.jpg |
