2006 FEH will not go into Hybrid mode after 30 minutes... help...?
Old Nov 1, 2016 | 07:57 PM
swinada's Avatar
Default Re: 2006 FEH will not go into Hybrid mode after 30 minutes... help...?
EV is disabled anytime the INTERNAL battery temperature reaches 96'F or above.
A/C comes on for the pack at 86'F and above but still allows EV.
and i assume the only way i can measure that temperature is with a ScanGauge 2? Or is there something cheaper available? I just cant afford a scangauge right now.
Old Nov 2, 2016 | 04:59 AM
08hybridok's Avatar
Nope, you can also buy a odbii adapter (like elm327) and the torque pro app ($5-10). And follow some directions posted on a link here somewhere (I can't do it from my phone) and you can see most of the same gauges.
Old Nov 3, 2016 | 02:01 PM
swinada's Avatar
Elm327 is ordered and on the way.
When are the fans supposed to come on for the battery? Certain temperature? When the actuator door opens up?
If i take the airfilter out to check while the car is running and not going in to hybrid mode, the door is open but the fans are not running.
Old Nov 3, 2016 | 02:48 PM
08hybridok's Avatar
Idk, but you might have more luck on the Facebook group https://www.facebook.com/groups/93606971242/
Did you find the link to get torque loaded with the SG data?
car2slo
Jan 12, 2016 06:16 PM
Hybrid2006
Jul 3, 2014 08:21 AM
uwviper
Sep 6, 2012 05:58 AM
