2006 FEH A/C blows hot
Old Jul 27, 2019 | 01:50 PM
Danny Mayer's Avatar
Default 2006 FEH A/C blows hot
I have checked the refrigerant, AC fans, Fuses, relay, Compressor seems to be always engaged. No luck. When AC is turned on i hear a CLICK but not other noises or hums. Any one have any tips on what it could be? Im afraid of frying the electric battery in the 100 degree CA weather. Thanks!
Old Jul 27, 2019 | 04:38 PM
Default Re: 2006 FEH A/C blows hot
Unfortunately, I can't provide any guidance on the A/C. You have a very real fear. I wouldn't drive it until you get the A/C fixed. I've seen many cooked packs due to inoperative A/C.
Old Jul 30, 2019 | 08:07 AM
Hippo the Hybrid's Avatar
Apparently, the Ford engineers arranged for the battery to shutdown once thermal sensors indicated that the battery reached an internal temperature of 140 degrees fahrenheit or 60C (from a 2010-12 Ford Escape Hybrid Emergency Response pamphlet). That said, I have seen a couple of internet posts that say the vehicle will shutdown once the battery reaches 100F although I consider this unsubstantiated. Personally, I think 100F is too low considering the operating temperatures of vehicles in the southern part of the U.S. including travelling in heavy traffic on blacktop. That said, it would be interesting if someone could chime in on the ideal as well as the usual lower and upper limits of nickel-metal hydride batteries of similar design and construction. Currently, I am running Hippo the Hybrid (2010MY) with a non-functional a/c system in temperatures of 30C.
Old Jul 30, 2019 | 08:35 AM
i can say with absolute certainty that 100°F is a hard threshold where the hybrid function is severely restricted and aggressive cooling begins. IMHO, Ford established 100°F as the upper limit of full power operation for the rear evap equipped models.
pmstirling
Aug 20, 2020 09:39 PM
Hybrid2006
Sep 26, 2019 11:40 PM
Searley86
May 17, 2018 04:31 AM
haroldo
Jun 11, 2008 02:12 AM
