08 FEH not going in EV mode unless air is completely off
Old Jul 20, 2019 | 07:23 AM
hphipps95's Avatar
Default 08 FEH not going in EV mode unless air is completely off
My FEH will not go into EV mode unless the air is completely turned off even at idle. The charging/assist needle is staying in the middle unless I take off then it moves to assist ever so slightly. When I'm driving it takes alot to stay at the mph I need. When going 60mph the rpm is staying at 3000. I've also lost 13mpg, even when driving around city and highway. Also, my circulating air doesn't work anymore. What could be the cause?
Old Aug 1, 2019 | 05:08 AM
notsonerdy's Avatar
Default Re: 08 FEH not going in EV mode unless air is completely off
my charge assist needle rarely budges from the middle as well, my mpg is ~27 fwy and 10 city!?... this is my first experience w/ hev technology.
Old Aug 4, 2019 | 12:38 PM
rowekmr's Avatar
I have the opposite issues (AC cuts off when in EV) but read in the owners manual that on the Auto, Defroster or Floor and Defroster settings when the outside air temp is freezing and above the engine will stay on to keep AC cold. You will have to hit the Econ button or another AC setting to regain the EV function of the gas engine shutting down. Hope that helps if not read that section in the Owner's Manual on HVAC settings.
noreception
Jul 26, 2023 09:39 PM
christophfur
Oct 13, 2017 12:58 AM
jpickering
Jan 12, 2016 06:36 PM
Baylor Green
Jan 9, 2009 09:53 PM
Scooters
Aug 14, 2006 06:41 PM
