12V power ( ever turns off ?) FEH 2008
Old Oct 29, 2007 | 04:53 PM
paweldryba's Avatar
Default 12V power ( ever turns off ?) FEH 2008
Hello all,
As alway, I have a question ( electic one ) I bought external GPS that charges using 12V outlet. I turned off the car while the GPS was pluged to 12V plug and ...... and GPS was still charging. When the 12V outlet stops charging ? Will it kill my battery ? Please help
thanks you all
btw I've checked the manual and I couldn't find any info
Old Oct 29, 2007 | 06:40 PM
GaryG's Avatar
Default Re: 12V power ( ever turns off ?) FEH 2008
Originally Posted by paweldryba
Hello all,
thanks you all
There are some outlets that do not provide power from the 12V system after key-off, but the one on the '05 FEH console will continue to drain and provide power from the 12V system. The HV battery provides no power if the key is off, so it will not drain.
GaryG
Old Oct 30, 2007 | 06:37 AM
Do you have two 12v outlets?
My car came with one by the shifter, that is on 100% of the time, and one on the dash by the vents that is only on when the key is on.
I like this! Now I have options for when to charge!
No key, or key to ACC means the 12v battery will power things.
With the key to run ( car started or not ) the 330v battery will power things for as long as possible by stepping 330v down to 14v.
When the 330v battery reaches a low enough level ( probably 35% ) it cuts off, and only the 12v battery will run things if for some reason you leave the key in "run" with engine off for a really long time. -John
Old Oct 30, 2007 | 10:09 AM
MAB's Avatar
MAB
We have a PT Cruiser that has two outlets, the covers on each show a battery (for always on) and a key (for ignition on).
Old Oct 30, 2007 | 10:18 AM
08hybridok's Avatar
The 08's have 2. 1 in dash (plus 110V outlet), and one in the rear console. Not sure if either is switched. I know the dash is always on.
Old Nov 8, 2007 | 02:03 PM
Doug121041's Avatar
I have a 2008 MMH and I have determined that both 12V outlets are powered at all times - a condition which I prefer.
Old Nov 8, 2007 | 03:12 PM
Mark E Smith's Avatar
Omnia Gloria Fugit
You might check to make sure one does not shut down after 15 min. This is possible and is done in other Ford vehicles that use the GEM or Smart Junction Box. I don't have the 08 wiring diagrams yet as Ford will not release them until next March.
Old May 9, 2010 | 10:52 AM
robingf's Avatar
According to the FEH 2008 Shop Manual, both of the power taps (one in dash, one in middle console) are always hot....no shutoff after any length of time (unless the battery drains, of course).
Old May 9, 2010 | 03:12 PM
colchiro's Avatar
I'm fortunate that my Garmin GPS will turn off if the power to it is cut, but since I have Sync, only have one 12v outlet, always on.
I picked up a female power cord and wired it into the ignition wire and plug my gps into that. Now it comes on and goes off with the ignition.
robbiedoo
Jan 4, 2013 04:41 PM
EazyMack
Feb 7, 2010 10:00 PM
Slick
Feb 1, 2010 12:50 PM
LucasR
Oct 14, 2009 07:09 PM
jscurrie
Oct 2, 2008 05:30 PM
