Alternative Fuel Vehicles Running biodiesel, E85, Natural Gas, Propane? Chat here!
How to Blend Your Own Fuel, and Why You Should
Old May 18, 2014 | 05:33 PM
  #181
Default Re: How to Blend Your Own Fuel, and Why You Should
This whole discussion, from the engine performance perspective not the national and corn side of things, is baloney.
The ethanol makes little difference to the engine. Go elsewhere and read a post worth reading.
Old May 18, 2014 | 09:10 PM
  #182
GeorgiaHybrid's Avatar
Bill,
If an engine is purpose built for alcohol use and a "mixed use" E20 or E30 use, you can get a tremendous amount of power out of them. Alcohol has less of a tendency to pre-detonate than gasoline, the engine will run cooler and cleaner, you can run a higher compression ratio with it, burn cleaner as far as emissions are concerned and the engine has a tendency to last longer in racing situations.
However, the engine will burn almost twice as much alcohol as gasoline to do that and our goal should be to use LESS fuel, not more no matter the type of fuel
Old Sep 21, 2016 | 05:26 AM
  #183
tommypress's Avatar
This is great informative stuff. Thank You!
HCivHybrid2005
Jan 25, 2013 09:57 AM
KimikoPi
Apr 17, 2008 08:32 PM
EZ2beGreen
Jul 10, 2007 09:54 AM
aspenboy
Mar 26, 2007 07:29 AM
