Website Questions & Input Suggestions and inquiries about Electric Vehicle Forums are welcome here.
Quick Math Help
Old Aug 7, 2005 | 10:42 PM
Jason's Avatar
Site Founder
Default Quick Math Help
For the mileage database, a small display bug was pointed out. To rectify it, I need to calculate the MPG for the tanks that are logged. It's late and my brain is fried. Can anyone else figure out the equation?
Known: Lifetime MPG, Lifetime Miles, Starting MPG, Starting Miles, Tank Miles
Need: Tank MPG
This may be really easy, but at 1:45 after all I've been doing on this thing... can't think! Thanks.
Old Aug 7, 2005 | 11:06 PM
tbaleno's Avatar
Default Re: Quick Math Help
can it be done? how can you ever know tank mpg without knowing tank gallons
You can maybe take a guess at it and assume all tanks had equal gallons. But this tank could be the exception to the rule.
I think you need tank gallons to do this equasion.
Old Aug 7, 2005 | 11:15 PM
Jason's Avatar
Site Founder
Haha. I think not! I'll figure it out tomorrow when I get some more sleep Trust me, it's possible.
BTW how do you think I calculate lifetime mileage when I never know how many gallons anyone ever uses?
Old Aug 8, 2005 | 01:40 PM
rjbarlow's Avatar
Conservative Republican
Jason,
If I could to real math.... Never mind. Math was not my subject. I have not had a math class since 10th grade geometry in 1975. I never had Algebra II, or Trig, or Calc, but...
I think what you are talking about can be figured by taking miles for a given tank, divided by total miles, to get a percentage that tank represents of the total miles. Multiply that number by the mpg for that tank, and you get X. Do the equation again for another tank and you get X1, and again for another tank and you get X2, and again for another tank and you get X3.... Add X, X1, X2, X3, etc together, and you get an mpg for the total number of miles entered.
Am I making any sense? It frightens me to think I might be. Don't ask me how I came up with this. I don't know.
Bob
Need: Tank MPG
Old Aug 8, 2005 | 01:45 PM
rjbarlow's Avatar
Jason,
Isn't this the same formula you use to figure out cumulative mpg for each member? All you need to do for me is use the formula you use now to calculate mpg, but subtract the "at start" numbers from your formula.
Does this make sense?
Bob
Jason's Avatar
Site Founder
Hmm. That requires a loop... a bit code intensive. I'm telling you... there IS a better way! I'll figure it out soon.
Old Aug 8, 2005 | 01:47 PM
Jason's Avatar
Site Founder
If any of you know PHP, maybe this could help. It's the code to calculate lifetime MPG.
Code:
$carQUERY=mysql_query("SELECT tanks, mi_start, mpg_start FROM cars WHERE cid=$cid");
$car=mysql_fetch_array($carQUERY);
// Grab tanks data
$tanks=0;
$tankQUERY=mysql_query("SELECT mi, mpg FROM tanks WHERE cid=$cid AND deleted=0");
while($tank=mysql_fetch_array($tankQUERY)) {
	$tanks_bit=$tanks_bit + ($tank['mi']/$tank['mpg']);
	$mi_tanks=$mi_tanks + $tank['mi'];
	$tanks++;
// Define car data
$mi=$car['mi_start']+$mi_tanks;
if($car['mpg_start']>0) {
	$mpg=$mi / ($tanks_bit + ($car['mi_start']/$car['mpg_start']));
} elseif ($mi_tanks>0) {
	$mpg=$mi_tanks / $tanks_bit;
} else {
	$mpg=0;
Old Aug 8, 2005 | 01:49 PM
rjbarlow's Avatar
Well, I don't know anything about computer programming either. You are on your own!
Old Aug 8, 2005 | 01:54 PM
rjbarlow's Avatar
Talking Re: Quick Math Help
Jason,
Now I am really treading into the unknown, I know NOTHING about computer language or programming. But what if in the third line of the partial quote below you changed ">0" to "=0" as the formula just to calculate the progress since adding tanks? Isn't that the code entry that tells the calculator that the mpg start may be something above 0, as in 23,151 miles in my case?
Bob
[// Define car data
} else {
$mpg=0;
}[/code]
txav8r
Nov 30, 2009 01:08 PM
ManyMPG
Honda Insight
Jun 16, 2006 10:29 AM
lkewin
Oct 20, 2005 12:33 AM
Jason
23
May 9, 2005 06:07 PM
