Tire pressure caps -- worked!
Old Apr 23, 2006 | 05:34 PM
bwilson4web's Avatar
Engineering first
Wink Tire pressure caps -- worked!
Hi,
Yesterday, I noticed one of my tire pressure caps was showing some yellow. Today, I measured it and found it at 35 psi. I topped it off at 40 psi and all four wheels are showing 'green.'
The four, 40 psi caps cost $6.00 and $5.00 for shipping, $11 total. Still it is a cheap and easy way to monitor tire pressure.
Bob Wilson
Old Apr 23, 2006 | 08:02 PM
bar10dah's Avatar
Default Re: Tire pressure caps -- worked!
Where did you order them from? The only ones I've seen online are at least $10, if not more.
Old Apr 23, 2006 | 08:13 PM
Engineering first
An Ebay seller. Search for item: 8059554408.
Bob Wilson
Old Apr 24, 2006 | 07:24 AM
livvie's Avatar
I guess they are better than not ever checking your tires. I find that they tend to not work as well over time.
Old Apr 24, 2006 | 08:02 AM
Engineering first
That is one of the reasons for the experiment. They do claim you need to replace them when you replace the tires. Also, I'd like to see a positive locking mechanism (aka., locking nut.)
The big advantage is checking is easy . . . just walk around the car or look at them when you approach the car.
Bob Wilson
Old Apr 24, 2006 | 12:21 PM
steveb's Avatar
Bob-- what site did you order the caps from?
Steve
Old Apr 24, 2006 | 01:00 PM
livvie's Avatar
Ok... so those of you that have never heard of google... air pressure valve cap....
try:
http://www.autogeek.net/kwtc.html
or
http://www.customwheelweights.com/st...gory_Code=tmmk
Old Apr 24, 2006 | 02:16 PM
Engineering first
Steve
I used:
www.ebay.com
search for item: 8059554408.
Good luck!
Bob Wilson
wdmark
Jul 9, 2008 10:32 AM
Oiler
Jul 19, 2007 06:50 AM
econoline
Mar 8, 2007 09:01 AM
Tim K
Jun 21, 2006 03:41 AM
