Resetting the Maintenance Light
Old Jan 30, 2006 | 10:03 PM
JakeBlade's Avatar
Default Resetting the Maintenance Light
Can anyone confirm the following :
In order to reset the Maintenance light perform the following---
While the car is on ---Odometer indicator on (visable --not the trip)
Depress and Hold the Odometer/Trip button and turn the car off then on while depressing the button. The Maintenance light should turnoff.
Old Jan 31, 2006 | 03:59 PM
JeromeP's Avatar
Default Re: Resetting the Maintenance Light
Funny, the dealers that have changed my oil in the past have reset this light and I have never done it myself, but I dno't think the sequence is correct.
Better check the manual, it is correct.
However, you have to make sure that when you do go to reset it that the vehicle comes on with the odo display already up. So, the start of the procedure is to bring the car to IG-ON. Adjust the display to odo and then turn off.
Then, while holding the odo switch down, bring the car to IG-ON. The reminder light will flash through this procedure. The odo should fill up with dashes and then count down to none and then return to a mileage display and the maintenance light will be off and reset for another 5k.
ukrkoz
Jan 10, 2014 02:39 PM
LexHybrid
Lexus RX 400h
Jul 18, 2011 10:10 AM
ssummers
Aug 1, 2008 04:03 AM
Zippie_Kandie
Jan 6, 2007 08:57 AM
Utah
Apr 17, 2006 08:56 PM
