Resetting tank average on TCH w/o Nav
Old Jul 31, 2008 | 11:19 AM
ssummers's Avatar
Default Resetting tank average on TCH w/o Nav
Is there a way for me to reset my tank average without actually filling my tank on my non-Nav TCH?
Thanks,
Scott
Old Jul 31, 2008 | 03:05 PM
UWAdventurer's Avatar
Default Re: Resetting tank average on TCH w/o Nav
Disconnect the battery? Just a guess.
Old Jul 31, 2008 | 03:11 PM
haroldo's Avatar
To what benefit?
The tank average is only an approximation based upon a short stretch of driving.
The true fuel economy indicator is the calculations over an extended period of time, such as a few months or even a year, so that you woul average in the various temperatures, driving distances, etc.
Over a short term, like half a tank or even less, would indicate...essentially, a non-sense figure.
My MPG meter shows 99MPG by coasting down a hill for 1/2 mile after filling up the tank, but what does that indicate?
Old Aug 1, 2008 | 03:56 AM
rburt07's Avatar
Ssummers may be trying to check the mpg between two points without having to fill up.
I had a new Ford a few years ago with a digital mpg readout. I could press the mpg reset and that made it easy to see your rather accurate mpg between cities of about 80 miles apart. Any shorter distances it would read a inaccurate high.
The TCH only resets when you fill the tank.
Old Aug 1, 2008 | 04:03 AM
haroldo's Avatar
Not sure, but when the fuel door is open and the cap removed, the system resets.
Does it reset because the door is open, or does the system reset because it detects that fuel is being added?
Maybe try removing the cap for a few seconds and see if it's the because the cap is off?
Zippie_Kandie
Jan 6, 2007 08:57 AM
Utah
Apr 17, 2006 08:56 PM
JakeBlade
Jan 31, 2006 03:59 PM
CLA
Honda Insight
May 23, 2004 06:04 PM
