Replacing 12VDC auxiliary battery - NHW11
Old Nov 26, 2009 | 01:53 AM
Wooster's Avatar
Default Re: Replacing 12VDC auxiliary battery - NHW11
Bob
I found your article fascinating - being a fan of Odyssey batteries for some time. (I have one fitted to my motorcycle.)
My 2004 Prius aux battery measures 12.1 volts, so it will need replacing soon.
However, looking at my UK, right hand drive version, there is a plastic fuse box / connector module mounted onto the existing positive terminal. See pic. Did your left hand drive Prius have the same module on the positive terminal? If you did - what did you do with it when you installed the Odyssey?
Regards
File Type: jpg
Old Nov 26, 2009 | 10:15 AM
bwilson4web's Avatar
Engineering first
Hi,
What I did was:
  1. Find the largest battery that would fit in the space.
  2. Order the screw/bolt version.
  3. Make two short jumpers with lugs.
  4. Used the bolts on both the ground and the 'fusible link' assembly to connect the battery.
In the car:
Notice the block of wood 'shims' needed to hold the battery in place. The terminals are close but not touching the frame. I could have increased the gap with something under the battery.
Bob Wilson
Old Nov 27, 2009 | 01:15 PM
Wooster's Avatar
Thumbs up Re: Replacing 12VDC auxiliary battery - NHW11
Bob - thanks for your prompt reply.
Yes, I understand how you electrically connected the battery. Your pictures and instructions are very clear.
But... How did you mount the fuse / connector block on the new battery?
The original battery mounts the fuse / connector block on the negative terminal - on the top face. But the negative terminal on the Odyssey battery is on the 'side' of the battery. So, what did you mount the fuse / connector block on?
Old Nov 27, 2009 | 06:10 PM
Engineering first
The jumper bolted onto the Odyssey battery handles it.
. . .The original battery mounts the fuse / connector block on the negative terminal - on the top face. But the negative terminal on the Odyssey battery is on the 'side' of the battery. So, what did you mount the fuse / connector block on?
On my original battery, the fusable link assembly is on the positive terminal located towards the front. So I'm bolted on to the short jumper holding it above the battery.
Bob Wilson
Old Nov 28, 2009 | 04:18 AM
Wooster's Avatar
OK - thanks for that.
ono
May 6, 2012 02:08 PM
bkushner
Nov 30, 2008 10:40 PM
titaniummd
Jul 16, 2007 11:06 AM
Felix
Mar 20, 2007 09:21 PM
sweetbeet
Apr 19, 2006 07:16 PM
