'pulse and glide' tips
Old Oct 10, 2005 | 10:15 AM
Catskillguy's Avatar
Default Re: 'pulse and glide' tips
Originally Posted by Catskillguy
http://hybridcars.about.com/od/owner...seandglide.htm
Here is a good article on Pukse & Glide
PULSE!! not PUKSE...LOL
Old Oct 11, 2005 | 09:32 AM
Obi Wan Ryobi's Avatar
I know this is in the impossible pile, but theoretically couldn't someone make a mod to deactivate the "tranny drag" effect. The car doesn't need to go into green arrow mode when you let off the gas, they just wanted to give it the feel of an automatic transmission, just like the "tranny creep", the car doesn't actually need to creep ahead when you take the foot off the brake. I would like to see that as a feature of future model years, part of an "eco" mode maybe, to always allow easy pulse and glide. Every time you take the foot off the gas, you just glide as far as you can, hindered only by rolling friction and air resistance.
Old Oct 11, 2005 | 10:11 AM
livvie's Avatar
That "tranny creep" was a big thing when they introduced CVTs. In the case of the HCH, they wanted that in before releasing the car to the public. But the eco button should be designed to do a lot more. Maybe 3 levels of eco would be nice for the extreme folks.
Old Oct 11, 2005 | 04:40 PM
Schwa's Avatar
When the battery is totally full the car will not do the coasting regen, so in theory if you told the car that the battery is full (fake battery ECU signals, like the plug-in mod does) you'll get that effect, but you don't wanna leave it that way for too long, or it will use up your battery too quickly because when it's full it tries to drain off the top couple bars more aggressively than normal.
Try it out some time by filling the battery, usually a good down hill will do the trick.
Old Oct 13, 2005 | 07:25 AM
foo monkey's Avatar
Aside from the safety issue (immediate access to the throttle), why not put the car into neutral, instead of feathering the throttle, to glide? Is the effect any different?
fradubio
May 30, 2006 12:58 PM
solecondad
22
Nov 3, 2005 11:57 PM
kuroyama
Sep 28, 2005 12:14 AM
ericbecky
Events & Gatherings
Aug 25, 2005 01:59 PM
helterskelter683
Aug 25, 2005 12:08 PM
