Prius Tires
Old Apr 22, 2008 | 09:48 PM
centrider's Avatar
Default Prius Tires
It looks that, after 30,000 miles my tires (stock, Prius tires) are going to need to be replaced. If anyone has a suggestion for new tires, I'm listening.
Old Apr 23, 2008 | 12:08 AM
SteveHansen's Avatar
Pragmatist
Default Re: Prius Tires
Toyota chose the OEM tires because they have low rolling resistance, and give you the best fuel economy. The Michelin Energy MXV4 tires have, I believe, the lowest rolling resistance of any available replacement tire.
30K miles on a set of tires can be very good or very bad. You have to compare with other tires on the same roads. Some areas of the country just have very abrasive roads, and tires in those areas just wear out quicker.
Old Apr 23, 2008 | 02:20 AM
bwilson4web's Avatar
Engineering first
Consumer Reports lists five tires as being low rolling resistance:
I'm using Sumitomo HTR T4s and have been quite happy. At $45/each from Tirerack.com, they are affordable and I bought my first set from the local Toyota parts department. Living in Alabama, we don't really have much roadway ice.
Bob Wilson
Old Apr 23, 2008 | 07:03 AM
centrider's Avatar
Thanks for the info, SH. I'll shop around. Texas it seems falls in that category.
Old Apr 23, 2008 | 08:00 AM
JimboK's Avatar
I have Michelin Hydroedges. Wouldn't have been my first choice for fuel economy, but a Saturday morning flat from an unrepairable road hazard, with substantial wear on all of them already, forced my hand. They were what I could get on short notice.
I estimated a 5-10% fuel mileage hit afterwards. Now after they are well broken in, I have recovered a lot of that. How much is impossible to say.
Other pros and cons: They wear much better than Integritys. I have 14K on them now and tread depth is from 1/32" to 2/32" less than new. They also handle much better, wet and dry pavement. They are noisier than the Integritys. And pretty expensive, >$100 each.
Old Jun 16, 2008 | 10:07 AM
kayakwill's Avatar
Anyone out there have any experience with General Altimax HP tires. It's time to replace the OEM's. These tires are supposed to be LRR and have a max pressure of 51psi - I'm thinking that I might be able to get better mpg with these than the Michelin X tires that I'm also considering.
Any comments?
Thanks, Will
Old Jun 21, 2008 | 09:48 AM
Picasso Moon's Avatar
I have a set of Michelin X Radials from Costco and have been very happy with them. No mileage hit. In fact they seem to be slightly better in the summer than the OEM's.
Old Oct 24, 2008 | 01:33 AM
06hch2's Avatar
F**k ExxonMobil
Any comments?
Thanks, Will
Did you buy the Altimax?
kklein
15
Dec 10, 2009 07:01 AM
sasparilla
Jul 19, 2007 08:21 PM
Billyk
Jul 14, 2007 11:36 AM
Rodney12
Jul 13, 2006 09:30 AM
