Oil changes
Old Jan 27, 2006 | 05:09 AM
krousdb's Avatar
Default Re: Oil changes
The OEM tires have a 65 aspect ratio, not 60. Assuming that your new tires are 195/65/15 Integritys, the revs/mile is 836. That is about a 2% difference. In my experience, the odometer over registers by 2% with the OEM tires so your new tires should make your speedo/odo more accurate. Your 5 mpg drop is about 10%. The other 8% is most likely due to the new tires. There is a huge hit associated with new tires. Give it 1000 miles or so and see if your mileage doesn't increase. It probably won't all come back due to the wider tread width which means more rolling resistance.
Dan
Old Jan 27, 2006 | 09:54 AM
jdenenberg's Avatar
Engineering Professor
Now to account for the other 8%, what is your air pressure in the new tires. You should inflate them to just below the maximum rated pressure (see the rating on the sidewall) but 2 lbls less in the rear.
If they are inflated to the pressure set by Toyota, your MPG will suffer. I run 42/40 in my Michelin MXV4+ tires. It causes the ride to be a little harder, but improves handling by making the Prius less vulnerable to swaying in the wind as well as improving the MPG.
JeffD
Old Jan 28, 2006 | 09:03 AM
JayTheHun's Avatar
MPG Tweaker
Originally Posted by galaxee
i'd be careful of dealer express lube places. they put so much pressure on the people to be quick, that quality often suffers.
In our town, at the oldest quick-lube place, the owner works down in "the pit," doing all of the actual oil changes himself.
ChadsMach1
Jul 10, 2010 08:27 PM
bendmac
Mar 1, 2006 11:32 AM
joe_tseng
Sep 20, 2005 08:14 PM
GoodMPG
Jun 14, 2005 07:33 PM
kenny
Jun 17, 2004 07:04 PM
