Need to stop the beeping!
Old May 3, 2004 | 05:44 PM
rationalrevolution's Avatar
I know that I can take the car in and sign a waiver to turn off the beeping when the car is in reverse, I plan to do this as soon as I have time.
Can they also turn off the beepng when the seatbelt is not on? If not, does anyone know how to do so?
I can't stand beeping, really, I don't even use an alarm clock because I hated the sound so much ( didn't have a radio alarm when I was in high school) that I got myself used to waking up early so I wouldn't have to listen to it.
I really hate beeping.
So, does anyone know how to disable these beeps? I plan to have the dealer turnoff the reverse beeps, but if anyone knows how I'd just assume do it tomorrow
Old May 3, 2004 | 06:34 PM
xcel's Avatar
Hi Rationalrevolution:
___The ability to silence the reverse beep is in your 04 Prius’ Owners Manual. I don’t own a Prius to tell you exactly where but it is a common question and easily fixed by the owner. Someone has posted the Reverse beep disable instructions over at Priusonline a number of times if you cannot find it directly.
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
Old May 3, 2004 | 07:29 PM
Jason's Avatar
Site Founder
I don't recall it being in the manual, though you may be right. I have already disabled the reverse beep and will be doing the same for the seatbelt beep (it's the same process).
Here are the instructions:
1. Power on (not neccesarily ready, IG-ON will do).
2. Set Trip/ODO to ODO
3. Power off.
4. Power on to ready (brake on).
5. Within 6 seconds, press and hold ODO for 10 seconds or more.
6. WHILE STILL HOLDING ODO *after* 10 seconds, Shift from P to R,
then back to P. Now release ODO.
7. You'll see in the trip pisplay "b on" or "b off".
8. Press ODO to toggle.
9. Now power off.
I THINK that to do the seatbelt, you simply unbuckle/buckle instead of shifting from P to R.
Old May 4, 2004 | 08:17 PM
3. Power off.
9. Now power off.
Wow, this is like some kind of secret viedo game code sequence
Edit:
Yes, this worked, on both counts, thanks!
BTW, for the seat belt you buckle the belt after having held the ODO for 10 sec, then you hit the ODO again to toggle, then unbuckle.
Very nice. I use my seatbelt, but obviously there re time when you want to take it off for whatever reason, to grab the cell phone or take your wallet out, or you simply haven't got it on yet in the parking lot, whatever.
Anyway, thanks.
Old Jun 13, 2004 | 09:25 AM
Jason's Avatar
Site Founder
I haven't been able to get the seat belt beeper to stop. I've attempted to many times. A few times I buckled and then unbuckled after holding 10 seconds (still holding ODO). Some I just put it in. Others I just took it out. Argh!
Old Sep 25, 2004 | 12:22 PM
Jason's Avatar
Site Founder
Update. 3 months later
I got the seatbelt beep to stop a while ago. I guess it just took another try?
gatonegro13
Sep 25, 2010 10:25 AM
haroldo
Jan 15, 2008 09:14 AM
belbe
Jan 9, 2008 06:18 PM
hamm3r
Jul 26, 2006 03:40 PM
