Funky Mouldy smell
Old Sep 19, 2006 | 11:36 AM
Tazmanhawaii's Avatar
Default Funky Mouldy smell
Got a 2006 Prius and it has about 2500 miles on it. Just yesterday I noticed a funky/mouldy smell coming from the A/C vents. After awhile it faded and I didn't smell it anymore. This morning, same thing. Anyone with any ideas as to what this could be caused by? I has rained a little lately and I've only washed the car 3 times.
Old Sep 19, 2006 | 03:00 PM
bwilson4web's Avatar
Engineering first
Default Re: Funky Mouldy smell
Do you hear water sloshing when you make a turn in 'stealth mode'?
Speculation but just in front of the windshield, under the wipers, is a pan that goes across the top of the engine compartment. It is possible for the drain to get plugged and then you would have a constant source of water. The outside air intake is just above this pan and feeds to the outside air filter located just under the glove box. Water on thhe filter == mold.
Let us know if this has anything to do with it.
Bob Wilson
Old Sep 19, 2006 | 08:29 PM
Thanks for the info. I heard that at PriusChat also. I'll have to check it out, but with the car only having 2500 miles on it and it's not parked under any trees, I am inclined to think that may not be what it is. But, one never knows.
Old Sep 20, 2006 | 01:40 AM
JeromeP's Avatar
Historically, the glues and adhesives that are used to attach dash duct work together are often times temperature sensitive and tend to emit strange odors, especially when there is a temperature chagne associated with a humidity change. I doubt it is liquid from the air intake vents or the area below the wipers, but it is the glue that holds the duct work together "reacting" to significant temperature changes.
Old Sep 20, 2006 | 03:52 AM
SoopahMan's Avatar
Could it just be condensate from the AC sitting and molding between uses? I've driven a non-Prius that did just that before.
Old Sep 22, 2006 | 11:41 AM
gpar2000's Avatar
I think you have a dead mouse in the vents . There is another thread that talks about it...+G
wxman3
May 24, 2007 07:08 PM
FAQOPEC
Apr 5, 2006 06:50 AM
tonto
Oct 14, 2005 12:15 PM
hawkGT647
Sep 29, 2005 08:34 PM
impala
Jun 16, 2005 11:13 AM
