better tries for prius I?
Old Dec 6, 2005 | 01:57 AM
philmcneal's Avatar
04 prius 350,000km
Default better tries for prius I?
i read that the stock prius I tries are garbage, so once they are worn out does anyone have any recommendations for tires that have very low road noise? I don't mind sacrafacing a few mpg for comfort and grip as well as long I can pump them to mid 40's psi
Old Dec 9, 2005 | 10:50 AM
JeromeP's Avatar
Default Re: better tries for prius I?
Tires the size that the Prius runs easily will be able to be max pressed to 45psi or better in most instances.
I would go for major name brand tires from Michelin or Goodyear. Other brands should be fine also, but the above 2 manufacturers are known for having the best tread compounds and technology. Although Nokian has a wonderful true all weather tire that includes a severs service rating, which means it qualifies as a traction tire during the winter and you can avoid having to get out and chain up. But they easily cost over 100 a wheel.
Curated Content Editor
Sep 19, 2014 06:20 AM
bwilson4web
Apr 29, 2008 11:32 AM
Pravus Prime
Off Topic
Apr 3, 2008 04:33 PM
Jason
Hybrid & Related News
Feb 21, 2008 02:35 PM
braced
Jun 4, 2007 10:46 PM
