Any Changes with 2005 vs 2004?
Old Dec 17, 2004 | 05:44 PM
Patzee's Avatar
I haven't seen the 2005 Prius and I'm interested in knowing if there were many changes from the 2004. I see the options have changed.
Thanks, Pat
Old Dec 17, 2004 | 09:07 PM
Totalshock's Avatar
Other than the options available (we here in Canada finally get nav and bluetooth as an option, if we want to lay out an additional $3k Cdn. for it....) I'm not aware of too many changes between the years. Granted, I haven't seen the 2005s in person, and all I really have to gon is just a salesperson's assertion that there are no differences.
Other than, I'd assume, the since-release fixes such as the "guess gauge" fix are in place out of the factory.
Old Dec 17, 2004 | 09:45 PM
flare's Avatar
Gas guage has been fixed, the Rear wiper is now standard and also two canopy pins have been added
Old Dec 27, 2004 | 11:13 AM
Patzee's Avatar
Thanks for the info!
Old Jan 12, 2005 | 03:56 PM
JeromeP's Avatar
Canopy pins? Can you explain?
Old Feb 24, 2005 | 10:44 AM
EdW's Avatar
EdW
This may or may not be the same thing, but the GM definition of a canopy pin are the little plastic retainers they install in the headliner to prevent it from sagging.
Old Feb 24, 2005 | 11:50 AM
Jason's Avatar
Site Founder
Hmm. Perhsp these were added towards the back to increase the headroom for the rear passengers.
Old Feb 24, 2005 | 03:32 PM
JeromeP's Avatar
Ok, I know what you are talking about now. I have noticed them. Smart idea. Although I have seen few cars out there without some kind of support or attachment in the center line of the headliner.
I suppose I would have understood what a canopy pin was if it was termed a headliner retainer.
Old Feb 26, 2005 | 03:35 PM
EdW's Avatar
EdW
Several GM, Ford, and Honda products have them, along with a few other Toyota products. These makes have all had problems with sagging headliners at one point or another. The push pins are probably a better (and cheaper) fix than using a stronger adhesive.
Agreed on the name, though, it's a bit confusing.
GNiel9
Aug 24, 2007 08:45 AM
us858
Oct 18, 2006 09:10 PM
PackerlandPrius
May 1, 2006 10:05 AM
waxmop
Jun 27, 2005 05:25 AM
