Will a TCH Hold a Double Bass?
Old Apr 1, 2007 | 07:53 PM
rharper's Avatar
Default Will a TCH Hold a Double Bass?
Thinking about a TCH but I play a double bass. Will it fit?
Thanks,
Roger
Old Apr 2, 2007 | 06:11 AM
Khabita's Avatar
Default Re: Will a TCH Hold a Double Bass?
No problem. Cut it into two equal halves lengthwise, stack them on top of each other, and slide them through the pass-through from the trunk.
You must have heard about the small trunk the TCH has. I can't imagine getting anything larger than, say, a mandolin into mine, so I'd suggest you take your double bass with you to the dealership when you do a test drive.
Old Apr 2, 2007 | 06:55 AM
hamm3r's Avatar
The trunk is not quite as small as you are making it out to be.
My best guess is that a double-bass will fit, but it would help if you post the dimensions (or yeah to be 100% sure definitely bring it with you on the test ride. You don't have to carry it IN to the dealership, just bring the TCH next to your car on the drive. That's how I tested the stroller).
I have no problems getting the largest, clumsiest, bulkiest double-stroller I have ever seen into the trunk, with room to spare.
Old Apr 2, 2007 | 07:57 AM
rharper's Avatar
Thanks. I know it won't fit in the trunk but if the passenger seat lies flat it may fit in the back driver side door and fit diagonally across. If the back seats fold down the body might fit in the trunk and the neck and scoll could rest on the console.
Roger
Old Apr 3, 2007 | 08:35 AM
ag4ever's Avatar
Dazed and Confused
The back seat folds down, but there is only an 8" tall by 15" wide opening to pass stuff thru. The battery sits against the back seat and takes up about 1/3 of the non-hybrid's truck space leaving us with diminutive sized trunks.
Your best bet is to put it in the cabin somehow.
Old Apr 3, 2007 | 09:25 AM
Sooty's Avatar
Thanks,
Roger
Unless you can get it in the back seat with the neck between the two front seats I'd say no it won't fit.
Old Apr 3, 2007 | 11:12 AM
abward's Avatar
Haha. Brings back found memories of me carrying around my cello in the backseat of my VW beetle in my high school days.
MagneticPearl06
Mar 19, 2009 08:49 PM
felixdacat
Sep 7, 2006 11:40 AM
Z71
Jun 7, 2006 11:49 AM
CGameProgrammer
Apr 24, 2006 08:14 PM
Artoodetoo
Dec 27, 2005 04:22 PM
