will OEM xm radio from Prius work in 08 Camry??
Just trying to figure out if the wiring is the same from the prius to the camry. I have an 05 prius and I just bought an 08 camry hybrid both have JBL Nav systems. One might think that the plug set for the xm radio that plugs into the back of the radio would be the same. The XM unit I have in the prius is the new one that will display 16 characters. Any thoughts??
Re: will OEM xm radio from Prius work in 08 Camry??
I don't have a direct answer for you, but I might have a roundabout answer for you.
I bought the Terk XM-Direct for my 07 TCH (which is the same radio wiring as your 08TCH). My Terk is compatible with the following Toyota/Scion model years:
Toyota
Camry 2006-2007 XMDTLK Displays All Functions
Camry Hybrid 2006-2007 XMDTLK Displays All Functions
Avalon 2006-2007 XMDTLK Displays All Functions
Solara 2006-2007 XMDTLK Displays All Functions
FJ Cruiser 2006-2007 XMDTLK Displays All Functions
4Runner 2006-2007 XMDTLK Displays All Functions
Scion
Model Model Years Terk Adapter OE Radio Model Remarks
xA 2005-2006 XMDTLK Displays All Functions
xB 2005-2006 XMDTLK Displays All Functions
tC 2005-2006 XMDTLK Displays All Functions
Therefore, I would assume that the wiring for the 05 Prius is not the same as the wiring for the 07+ TCH, otherwise the 05 Prius would have been listed on the comptability chart listed above.
Toyota
Scion
See my thread "Terk XM-Direct". You can buy it for $99 right now from the xmfanstore.com, and it sounds like you are willing to install it wourself.
You might check to see if all you need is the cable from the box to the head unit. I think the "fit kit" that includes cable, brackets, antenna and other miscellany is around $125.00, I got the whole kit from www.toyotapartspeople.com for around $280.00 for everything. A trip to the local dealership where they printed out the 14 page instructions, and I was ready to go.
phenderson
11-30-2009 01:05 PM
mickster
06-07-2006 04:57 AM
