Where to put jack stands?
Old Apr 11, 2011 | 02:25 PM
litespeed's Avatar
Professor Emeritus
Default Where to put jack stands?
I searched and could not find any good pics or info. I want to get the car off the ground. I can see where the "floor jack points" are in the front and rear. That is obvious.
Where are you guys putting the jack stands after you get the car in the air? I don't want to damage the frame/body.
Old Apr 12, 2011 | 05:17 AM
jdenenberg's Avatar
Engineering Professor
Default Re: Where to put jack stands?
If you make a cushion out of a piece of wood that has a slot for the flap of metal, you can safely put either the jack or the jack stand anywhere near the marked position.
JeffD
Old Apr 12, 2011 | 05:43 PM
litespeed's Avatar
Professor Emeritus
Are you talking about the "marked position" on the pinch welds? I'm not a big fan of using jack stands in those areas.
I saw a detailed thread on where someone replaced their struts. It looked like the jack stands were farther in.
I just wanted to rotate my tires. I just used the spare tire to do it using the jacking points in the center of the vehicle. I just had to jack it 4 times to get it done.
I still would like to know the safe places for future reference.
Old Apr 12, 2011 | 07:45 PM
Mendel Leisk's Avatar
I raise the front of the car with the front central point, the put safety stands at those two front scissor jack points, the marked points at the bottom edge of rocker panel. Then repeat with rear.
bwilson4web
Aug 22, 2006 08:19 AM
bar10dah
Jul 13, 2006 03:38 AM
lkewin
May 2, 2006 10:58 AM
CamelFilters
Mar 21, 2006 06:07 PM
nysebull
Sep 9, 2005 02:08 PM
