Where are the Headlight Adjustment Screws?
Old Aug 10, 2007 | 09:57 PM
Eskimonio's Avatar
Default Where are the Headlight Adjustment Screws?
Normally, my vehicles have easily accessible headlight adjustment screws mounted on top of the back of each headlight.
Lift the hood, get your Philips-Head and in a couple of turns, you're in business.
No Joy so far in locating these on the CamHy.
Help.
Old Aug 11, 2007 | 01:37 PM
Squint's Avatar
Malcontent
Default Re: Where are the Headlight Adjustment Screws?
It's not a screw but you do use a Philips screwdriver to make the adjustment. Look for a 2 cm diameter metal disc with a serrated lip. It's between the high beam and low beam and about 5 cm below the midline of the high beams.
Old Aug 12, 2007 | 08:16 AM
Eskimonio's Avatar
Thanks Eric, I found it.
Do you have any more information you could share?
i.e. Since there's only one per side, are these for lateral or height adjustment, and what effect does a clockwise turn of the screwdriver yield?
I'd rather learn from your experience first, before I start fiddling with it.
Old Aug 12, 2007 | 02:00 PM
SPL's Avatar
SPL
Eskimonio — Here's the Repair Manual information about adjusting the TCH's headlights.
Stan
File Type: pdf
Old Aug 13, 2007 | 04:08 AM
Squint's Avatar
Malcontent
As far as I know, there's no horizontal adjustment. I've attached the part of the service manual that covers headlight adjustment.
File Type: pdf
Old Aug 13, 2007 | 10:26 AM
Eskimonio's Avatar
Thanks gents.
Mind pointing me to where I might find a digital copy of that repair manual?
I've tried the one at CamryManuals.com and it's giving me fits on the burn. https://www.greenhybrid.com/discuss/...ad.php?t=14869
************ Edit ************
Nevermind on question above...it was pointed out to me that Nero won't burn that image...ImgBurn worked fine. Thanks!
LEAKYTCH
Nov 3, 2012 04:57 AM
Eskimonio
Aug 18, 2006 11:04 PM
hamm3r
Jul 7, 2006 09:50 PM
debdeb
Honda Insight
10
Feb 20, 2006 01:42 PM
ericbecky
Jul 10, 2004 04:04 PM
