What brand of gasoline do you use?
Old Nov 11, 2006 | 04:16 PM
gandyfire's Avatar
Default Re: What brand of gasoline do you use?
I usually buy Hess or Shell cuz I get 5% off with my card. Most name brands of 87 octane are fairly equal. And ditto on the no Citgo or Valero, I think everybody should boycott them even though it would hurt the independant dealer who leases the pumps.
Old Nov 11, 2006 | 04:39 PM
schmidtj's Avatar
Keeping Toyota Solvent
Originally Posted by skywagon
I have a large tank with a pump ect for 100 octane low lead aviation fuel for my aircraft, this fuel has no ethanol, and a very long storage life which modern auto fuel does not have. A fifty fifty mix works well in my cars, trucks and Harley's. never gotten under 40 mpg with the TCH.
You pay your "Road Use Taxes" on the Aviation Gas you use in your car? I'm sure your do.
I would think even "Low Lead" Avgas would do a number on your catalytic converters (plural) in no time.
Old Nov 11, 2006 | 05:16 PM
Shining Arcanine's Avatar
Originally Posted by bmgoodman
I tend to go for any branded gas station (excluding Citgo and Valero because they are Venezuelan). I avoid getting gas while the gas delivery truck is at the station because they tend to stir up sediment as they pump into the station's tanks.
While Citgo is owned by Venezuela, Valero is a US company. They used to be a natural gas company until they sold their natural gasoline business and started buying gasoline stations. The New York Times ran an article on them and it made it very clear that they were a US company. Why do you think that they are Venezuelan?
Old Nov 11, 2006 | 05:32 PM
schmidtj's Avatar
They get a lot of crude oil from Venezuela. The country is run by moron.
Old Nov 11, 2006 | 07:19 PM
skywagon's Avatar
I would think even "Low Lead" Avgas would do a number on your catholic converters (plural) in no time.
Yes on the taxes, the 2 harleys run straight 100LL, Lexus, and General Motors vehical run 50% 100 LL. 50k on one 70K on another, only problem on one had to remove o2 sensor and clean. Better milage, better all around performance, computer can run timing way high due to no ping situation. is it worth the $3.50 extra per gallon? I think the extra perfromance and milage may balance it out. Have never got under 40 MPG with the TCH even with sloppy driving. PS lead in fuel is a lubricant for the valves and seats and engines love it.
Old Nov 11, 2006 | 07:33 PM
Paulgw's Avatar
People in glass houses shouldn't throw stones!
Old Nov 11, 2006 | 07:37 PM
Big-Foot's Avatar
Currency-to-hydrocarbons
We ran 130 Avgas in our racecars for a long time.
Compression ratios up to 14.5:1 .. Then they quit making/selling it.
We gave 100LL a try and found that we dynoed with the same power.
Had the fuel analyzed (Phillips) and were told that it had more lead content (by many times over) than did leaded automotive fuel. The vapor point of the AV fuel was a lot lower as well. While we didn't have any problem with vapor lock, some guys did. We used positive displacement eletric fuel pumps.
Gman is right. Engines (particularly their valves) love lead. The lead not only acts as a lubricant but a coolant as well. The lead helps carry far more heat away from the engine.
Problems in running a mix of leaded / un-leaded -
The lead will foul o2 sensors as well as poisoning the catalytic convertor with repeated use. o2 sensors will clean themselves (by heat) if not fed a continous diet of lead. Catalytic convertors will not fully recover and they will produce less output heat. The lower output heat will cause the secondary o2 sensor to set a code in the ECU indicating that the engine is not running efficiently. This will ultimately turn on the SES light on the dash.
The final problem is that it's actually illegal to introduce leaded fuel (except in the case of an emergency) to a vehicle driven on public roads that was designed to run un-leaded fuel.
Old Nov 11, 2006 | 07:52 PM
You do realize that the lead destroyed your three way catalytic converter and you are now putting harmful hydrocarbons into the atmosphere that will cause lung illnesses and lead poisoning in the general population, right?
Old Nov 11, 2006 | 08:18 PM
Paulgw's Avatar
Originally Posted by Big-Foot
......Problems in running a mix of leaded / un-leaded -
I think you missed an important reason lead is not good, that is it poisons the environment not to mention the people and especially children who have to breathe the lead polluted air.
Old Nov 11, 2006 | 08:23 PM
Big-Foot's Avatar
I missed nothing. Read the last sentence of my post.
Thanks..
