Warped Rotors...
Old Jan 15, 2008 | 11:00 AM
Squint's Avatar
Malcontent
Default Re: Warped Rotors...
I think that if your lug nuts are over 103 N*m, the last person who touched them owes you new rotors.
Old Jan 17, 2008 | 06:52 AM
livvie's Avatar
Originally Posted by To D Lake
I thought rear disc brakes used a top hat style rotor with a small e-brake shoe inside the hat? That is the way my Ford and Nissan are set up. I guess I'll have to take a look at the set-up on my TCH when the weather gets a little nicer.
Robb
some cars have that, other don't. my cooper doesn't do it that way. my calipers will close.
Old Jan 17, 2008 | 11:35 AM
To D Lake's Avatar
I just took a look at my TCH rotors and they are the top hat style. So at least we don't have to worry about warpage due to e-brake...
Robb
Old Jan 17, 2008 | 05:32 PM
agnosto's Avatar
Yup, that what was happening to my ex 1999 4Runner that I had to replace the rotors every 10k-12k miles and finally figured it out that dealership and or Discount Tire would over-torque the wheel nuts when I had it for tire rotation (made me so mad.....)......... and so never ever again as I am doing tire rotation myself with a torque set to 76 ft-lbs and never had the issue again... simply do not trust when they tell you "we used the correct torque setting to tighten the wheel nuts" yeah right...
also how many dealrships you think they follow the proper sequence to remove tires equipped with wheel locks (tire removal: first the wheel lock and then the rest wheel nuts. tire placement: first wheel nuts and then wheel lock.) surprise, surprise, not many...
JCPerformance
Sep 3, 2013 08:30 AM
tecz0r
Mar 26, 2013 07:16 PM
Seeburg220
Jul 14, 2011 12:05 PM
zadscmc
Jun 14, 2005 07:22 PM
