Video Output on Nav
Old Nov 7, 2007 | 08:03 PM
mikieboyblue's Avatar
Default Re: Video Output on Nav
Originally Posted by Pepsi
No, I don't really mind it that much. I figure its a software issue and would require a firmware hack and I'm not about to put that much time into this to fix that part.
Is it there all the time?
Old Nov 8, 2007 | 04:11 PM
Pepsi's Avatar
Yes, the "check your surroundings" text is always there when it's displaying video from the video feed.
Old Nov 8, 2007 | 06:50 PM
After using it for some time, could you let us know if there are any other side effects of making the NAV think you are in reverse when you are truly moving forward?
Old Nov 12, 2007 | 02:25 PM
Pepsi's Avatar
I ended up putting the reverse signal on a switch. Having it on all the time will make the nav unit think you are going backwards between GPS signals. When you switch back from video to navigation, it takes around 5 seconds for the position to start updating correctly.
Old Nov 12, 2007 | 04:36 PM
Makes sense. Have you attempted to "watch" a video while using the nav to guide you? Does it go nuts? I would like something that can be watched while driving even when the nav is navigating you.
Old Feb 4, 2008 | 01:10 PM
Hi Pepsi,
How has this been working for you? Do you have any thoughts on the above quoted questions?
Thanks,
Mike
JavaJ
Apr 17, 2007 11:06 PM
lakedude
Off Topic
Aug 22, 2006 10:49 PM
Adam_HybridCivic
Apr 19, 2006 07:43 PM
