UPDATE: Car Keeps Stalling after everything.
Old Nov 14, 2017 | 02:33 PM
Xavega4217's Avatar
Default Re: UPDATE: Car Keeps Stalling after everything.
First, the "C" codes are red herrings right now. Until you sort out the P0A0F code, you're going to get the "C" codes. Ignore them. Any time there is a significant problem with an HV ECU related system, you get those "C" codes.
Are you absolutely, positively 100% certain that you have at least 5 gallons of gas in the car?
For the Camry, P0A0F-534 = fuel level not sufficient to start the engine
This can be permanently set if you ran it out of gas at any point. It stays set until > 4 gallons of gas are added. I use a whole 5 gallon can to make sure.
i added an extra 2-3 gallons, nothing and worse now the car doesnt even attempt to start - Waiting for a friend to come by and stick the codes in
Old Nov 14, 2017 | 02:55 PM
I suspect that you haven't started the car in a long time and that you've just been spinning the ICE for several seconds with MG1 thus running the hybrid battery down.
Old Nov 16, 2017 | 02:38 PM
Xavega4217's Avatar
It was a fuse. to the HV Battery. One fuse caused this giant headache
Old Nov 16, 2017 | 05:54 PM
Which fuse?
Old Nov 16, 2017 | 06:48 PM
Xavega4217's Avatar
Which fuse?
Hybrid Battery Fan
Old Nov 16, 2017 | 08:32 PM
That shouldn't generate a P0A0F. There are specific codes for the fan, and it wouldn't throw a code until it actually tries to turn the fan on.
dwichman
Aug 25, 2010 02:31 PM
Boo Gas
Apr 23, 2009 01:11 AM
Freeze
Jan 1, 2007 07:09 AM
noflash
Dec 13, 2006 05:43 PM
nbalthaser
Mar 26, 2006 03:08 PM
