UPDATE: Car Keeps Stalling after everything.
Old Nov 12, 2017 | 12:55 PM
Xavega4217's Avatar
Default UPDATE: Car Keeps Stalling after everything.
i have posted before and this is my update:
It all started with an ABS issue - drove it from Orlando to Miami with a bad ABS due to i was far from home and it be 3 AM.
Once i was home i took out the ABS relays and this is where my life went to hell.
the Relays caused a drain - killed my 12v - no biggie i can recharge and find the drain.
a week went on and the Hybrid battery got a malfunction too AWESOME!
finally replaced the ABS and tried starting it up - car stalled. immediately. - This is the BIG issue!! and where i am stuck at.
codes said it was the ECU - which was caused by the drain i assume
c1259 and C1310- toyota gave me a diag and it pointed to the "Power Management ECU"
SO. i fixed the ABS - Fixed the Drain - Fixed the Hybrid Battery - Replaced the ECU ( not the SKID ECU )
and the car STILL does not want to stay on!
THIS is what the Toyota mechanic gave to me : https://imgur.com/a/4vhfA
These are the codes AFTER the everything was done : https://imgur.com/a/N5AbV ( samething)
my next idea is to check/replace the SKID ECU and after that Sell the car from hell.
i know im asking for a miracle - car has been sitting there since AUGUST.
Old Nov 12, 2017 | 04:22 PM
Default Re: UPDATE: Car Keeps Stalling after everything.
What is the detail code on the P0A0F?
Old Nov 12, 2017 | 04:45 PM
Xavega4217's Avatar
Engine Fail to start
Old Nov 12, 2017 | 07:25 PM
No, that's the description. There are 4 detail codes associated with P0A0F indicating source of the error. By clicking the little blue snowflake by the error code, you are given the detail codes.
Old Nov 13, 2017 | 12:02 PM
Xavega4217's Avatar
will be looking into it today or tomorrow. the software is a friend and he has been saving my butt
Old Nov 13, 2017 | 12:35 PM
Anytime you see the little blue snowflake, it's critical you click it. For the Prius, P0A0F has 4 different detail codes pointing to 4 different sources for the failure. Without the detail codes, you're just guessing.
Old Nov 13, 2017 | 04:31 PM
Xavega4217's Avatar
my friend has the software and i have to work on his time - i cant be pushy he did the ECU and the battery for me already and we thought that the car would be up by now.
give me a day or 2
Old Nov 13, 2017 | 04:51 PM
First, the "C" codes are red herrings right now. Until you sort out the P0A0F code, you're going to get the "C" codes. Ignore them. Any time there is a significant problem with an HV ECU related system, you get those "C" codes.
Are you absolutely, positively 100% certain that you have at least 5 gallons of gas in the car?
For the Camry, P0A0F-534 = fuel level not sufficient to start the engine
This can be permanently set if you ran it out of gas at any point. It stays set until > 4 gallons of gas are added. I use a whole 5 gallon can to make sure.
P0A0F-533 can also be low fuel related.
P0A0F-204 or 205 are likely either Bad HV ECU or Engine ECU (in that order)
P0A0F-238 is "tow it to the salvage yard" with issues in this order:
Engine
Hybrid vehicle transaxle assembly (shaft, gear)
Transmission input damper
Wire harness or connector
Hybrid vehicle control ECU
Old Nov 13, 2017 | 05:43 PM
Xavega4217's Avatar
Engine
Im not. ABSOLUTELY. No. I drove it home from Orlando. it has more than a quarter tank in it.
i didnt run out of gas but i was VERY close to running out near orlando and had to stop. same time the ABS decided to fail completely.
You mentioned HV ECU and Engine ECU - i replaced the one that goes behind the engine. near the brake fluid.
SO i decided to video the entire thing.
- Gas and all.
Old Nov 13, 2017 | 05:48 PM
Xavega4217's Avatar
17.1 tank size divided by 4. = 4.3 per quarter and im right above the the 1st quarter
ill put in 4 gallons and that should satisfy the 5g mark
