Toyota Camry 2010 - P0A94 DC/DC Converter Performance
Old Sep 30, 2018 | 01:29 AM
Azan's Avatar
Default Re: Toyota Camry 2010 - P0A94 DC/DC Converter Performance
Hi Poa94 dc dc converter Performance code , if your car is giving trouble at high speeds or after driving over 20 minutes, and car goes into limp mode. Check your tranny Fliud if it’s black or purple you will need a new transaxle, I had the same problem in the car tried every bloody thing related to hv but in the end it was the transmission and it fixed th problem. I did lot of research but found no straight answer so now my car is fixed decided to leave feed back here so might be helpful for someone. My car was Toyota Estima Hybrid . Same engine etc and Camry Vellfire , Alphard, Etc
Old Oct 22, 2018 | 04:27 AM
Phildo's Avatar
I’ve got a 2010 Camry hybrid with 147,000km on it.
It’s giving the P0A94 code, along with the 127 sub-code.
Has anyone managed to fix this error without replacing the transmission?
Old Oct 22, 2018 | 04:34 AM
Azan's Avatar
Hey have tried everything drain your tranny oil if black or purple then u need a new tranny
Old Oct 22, 2018 | 07:14 AM
See attached. Order of likelihood:
  • HV relay assembly
  • Inverter with converter assembly
  • Service plug grip
  • Frame wire
  • Wire harness or connector
  • Hybrid vehicle transaxle assembly
File Type: pdf
Old Apr 29, 2020 | 12:43 PM
Omar Ajarmaa's Avatar
I have the same problem with my car. Didi you solve it
Old May 12, 2020 | 11:21 AM
Kayden Bathory's Avatar
I also am having the same problem, did replacing the transmission fix it? I got a 2nd hand inverter and changed the fluid in the transmission, which was black, same issues tho.
Old May 12, 2020 | 01:55 PM
As has been mentioned above, there are over a dozen detail codes associated with P0A94 (16 by my count). Each detail code has its own set of diagnostics. The possible sources of failure are as follows (in alphabetical order):
Battery smart unit
Cooling fan system
Engine assembly
Engine room R/B
Frame wire
Fuel level
Fuse (INV W/P)
HV relay assembly
Hybrid vehicle control ECU
Inverter cooling system
Service plug grip
Water pump with motor & bracket assembly
The most common causes across all detail codes are 1) inverter and 2) transaxle.
You need to get the detail code associated with P0A94, or you're just taking shots in the dark.
Old Jun 17, 2020 | 04:37 AM
Phildo's Avatar
Update on my car: I lived in denial for several months while the car was parked in my front yard.
I finally gave up and bought a replacement transmission.
Since it was fitted there hasn't been a problem with the car.
Old Jun 29, 2024 | 03:13 AM
aa4123's Avatar
I had the same issue on a 2011 Camry Hybrid, high mileage ex-taxi. Driving above 90kph for more than around 10 min would set the P0A94-127 code. Replacing the transmission fixed the issue.
Old Jan 3, 2025 | 08:24 AM
ChamathD's Avatar
Hey,
so did you manage to get this repair done? Were you able to find what needed to be done?
THANKS!
mfalk22
Jun 16, 2019 06:04 PM
accent2010
Mar 22, 2019 08:49 PM
alinutz
Jul 11, 2017 01:46 PM
vasili
Toyota Motor Corporation
Sep 16, 2015 06:11 PM
talgat_duisenov
Apr 30, 2013 09:54 AM
