having problems with my car. need help
Old Apr 29, 2013 | 02:26 PM
talgat_duisenov's Avatar
Default having problems with my car. need help
Hi guys,
I'm currently having problems with my car. Specifically, After driving for about 5min, gas pedal doesn't react at all.
I have a Camry Hybrid 2007. 84800 miles.
I went to the dealer and got the following errors:
p0a94 DC/DC converter performance
p3004 High Voltage power resource
p3108 Lost communication with DC system control model
Mechanic said that I need to replace hv battery but i don't believe him since i'm not getting any error saying that i have to replace my battery.
After resseting the errors, the car operates fine.
Please help what the problem could be?
Old Apr 29, 2013 | 05:00 PM
haroldo's Avatar
Default Re: having problems with my car. need help
Bring it to a second dealer and see what they say
Old Apr 29, 2013 | 09:23 PM
I would be glad to but we have only one dealer. lol
I'm from Kazakhstan
Old Apr 30, 2013 | 09:54 AM
GeorgiaHybrid's Avatar
Talgat,
Can you get the rest of the codes that they pulled from your ECU? Each of those codes should have another 3 digit code behind the original one IE: P3004-133. To give you an idea, the first code you listed has 16 different sub codes, the second has 6 and the last one has 3 codes.
If you can find those out, I might be able to point you in the right direction. These Camry's are very complicated cars and what APPEARS to be wrong often times is not. How often does this occur? How long has it been happening? Does this just happen in cold weather, warm weather or both?
The cause for what you have experienced could be as simple as a loose wiring harnes connector all the way up to a bad hybrid battery, bad DC to DC convertor, a bad DC to AC invertor or a bad ECU
larryr
Jul 16, 2019 08:24 AM
Culpritgrl
Oct 9, 2009 05:59 AM
talljetman2
Jan 7, 2009 10:47 AM
Jerry&Natalie
Jun 10, 2007 08:31 AM
