Tire Wrench
Old Sep 7, 2007 | 12:32 AM
beng's Avatar
Default Tire Wrench
Has anyone noticed that their tire wrench does not fit properly? I had to use mine today for the first time. On the very first lug nut, it felt a bit loose, but I did not pay too much attention to it. Then when I pulled off the wrech, I saw the damage it did to my alloy wheels! I ended up using a cloth to wrap the wrench with for the remaining lug nuts.
I'm going to see my dealer on a better fitting wrench and wanted to see if anyone else's wrench fits loosley.
Old Sep 7, 2007 | 06:32 AM
cast_and_blast's Avatar
Default Re: Tire Wrench
I used mine when I removed my rear wheels to install my rear mudflaps - seemed to fit quite well and I didn't notice any damage to the lug nuts or the wheel.
Did the wrench rub on the wheel or did it slip that you have wheel damage?
Scott
Old Sep 7, 2007 | 08:14 AM
beng's Avatar
The wrench never slipped, as I loosened the nut, the wrench rubbed against the alloy wheel leaving a rather large scratch in it. Not sure what the dealer can or will do. Might end up goint toa local automotive store to buy a proper fitting wrench.
Old Sep 7, 2007 | 08:46 AM
skywagon's Avatar
Scott
Another one that thought they had to remove wheels to install the flaps!! ROTFFLMAO!
Old Sep 7, 2007 | 08:55 AM
andrewbmoore's Avatar
I just rotated my tires using the included wrench last weekend (which means A LOT of wrench usage). Everything went fine. But... on my 2005 Camry, I tried the same procedure last year and had the same problem you did. It turns out that I hadn't put the wrench on the lug nut perfectly straight which created a lot of slack when pushed hard. You have to be very careful about making sure the wrench is fully and squarely over the lug nut. Of course, it is entirely possible that your wrench has a defect.
No, I chose to. I prefer to be able to see my work; by removing the rear wheel it makes it very, very easy to work on. Takes 2 minutes to take off the wheel - what's the big deal?
Scott
Old Sep 7, 2007 | 09:38 AM
skywagon's Avatar
Scott
MN lugwrench (pair of pliers) lol
c0ugar69
Mar 16, 2012 10:07 AM
Hybrid_SUV
Mar 10, 2008 12:14 AM
MrBond
Dec 23, 2006 06:40 PM
DGH
Sep 29, 2006 12:06 PM
KS-Kidd
May 4, 2006 12:11 PM
