Oil filter wrench
Old Sep 23, 2006 | 03:59 PM
DGH's Avatar
DGH
Default Oil filter wrench
Greetings,
What is best for the Escape, cup or strap style?
I believe the cup size is 74mm, 14 flat, but I can't find one anywhere.
Thanks...Dan.
Old Sep 23, 2006 | 04:17 PM
spud's Avatar
Default Re: Oil filter wrench
Cup type.
Autozone has 'em. Brand is called 'OEM Industrial' PN-25401
Old Sep 23, 2006 | 04:31 PM
DGH's Avatar
DGH
Spud,
Thanks, got one on hold till Monday.
Dan.
Old Sep 28, 2006 | 07:23 AM
glennb's Avatar
Picked mine up at an AutoZone yesterday.
Brand: "OEM Industrial" OEM Company, Mineola, NY
Part No: 25401
Part Name: Oil Filter "B" Cap Wrench
Made In: China
Old Sep 28, 2006 | 12:39 PM
nitramjr's Avatar
All else fails, use your hand. When I did my first oil change on the 2005, I had already drained the pan when I discovered that none of my filter wrenches fit. I managed to get it off by hand although it wasn't easy. It can be done though.
I've found out that the first oil change is the worst as far as getting the filter canister off. I don't reuse the o-rings but for some reason the replacement o-rings don't hold it on as tight. Maybe because I lube them up for installation.
Old Sep 28, 2006 | 09:28 PM
DGH's Avatar
DGH
Thanks for the help, if the wrench won't cut it, I'll try the brute force method.
Dan.
Old Sep 29, 2006 | 06:28 AM
glennb's Avatar
I used a strap style wrench on my first change. It made me a little nervous to impart the strap forces on the plastic/composite material that Ford used on these oil filter housings. [I'd hate to see how an oil change mechanic in a hurry would react.]
Having the wrench with the exact hex will alleviate that worry. $4.99 plus tax at AutoZone
Old Sep 29, 2006 | 12:06 PM
nitramjr's Avatar
Originally Posted by glennb
IHaving the wrench with the exact hex will alleviate that worry. $4.99 plus tax at AutoZone
Part No: 25401
Made In: China
Any money I don't have to spend either at Autozone or supporting the Chinese economy is money well not spent.
Besides, I have two built-in, one size fits all oil filter wrenches. One left handed and the other right handed....
GatorJ
Jun 6, 2014 12:03 PM
dgyimao
Dec 31, 2009 09:38 AM
bugs
May 26, 2009 12:05 AM
jscurrie
Jul 30, 2007 12:05 PM
