Tire Presure
Old Aug 24, 2007 | 04:25 AM
darrelr's Avatar
Default Re: Tire Presure
My dealer had the tires at 32psi, and I have been averaging 35.4mpg. Last tank I increased the pressure to 40psi, and I got 36.7mpg. I am travelling over the next week, and will see if the gas mileage keeps up. I did notice that there were corners that I could get around now without the ICE that I couldn't get around before. The car seems to handle better with the higher pressures, and it rolls easier from a stop (much easier to keep the ICE off).
Old Aug 26, 2007 | 09:29 AM
paul29's Avatar
Originally Posted by rmorrow
I was wondering the same thing. What I was planning on doing was reading the pressure at home, after the car sits overnight, and then drive to the gas station and measure again. If I see a significant difference, I'll be able to compensate for it. (ie. if every tire is up 1 psi, then I'll fill to the desired level minus 1 psi).
To get the desired pressure , add the 1 psi difference , when they cool they will be at the desired pressure .
Old Aug 27, 2007 | 03:51 AM
rmorrow's Avatar
Whoops. What I was thinking and what I was typing were two different things. Thanks for the correction.
Old Sep 7, 2007 | 04:43 AM
darrelr's Avatar
As a follow up to my previous post, I have logged 3159 miles with 40psi in the tires, and my gas mileage has averaged over the 6 tanks 37.2mpg, versus the 35.4mpg with 32psi in the tires. The tires show no extraordinary wear.
MPLSMN
Feb 16, 2010 04:59 PM
twolostminds
Nov 17, 2008 08:54 PM
Oiler
Jul 19, 2007 06:50 AM
mg48
Jan 13, 2006 07:53 AM
