The tire pressure light sensor won't go off. Sigh.
Old Mar 3, 2013 | 06:51 PM
John Trimble's Avatar
Default Re: The tire pressure light sensor won't go off. Sigh.
I hope I caan ask this here. 2007 Prius. Is there a pattern to the tires regarding the TPMS? In other words is it set up so the the wheels are numbered and in which order? example, right front #1 Left front #2 etc?
Old Mar 3, 2013 | 08:52 PM
GeorgiaHybrid's Avatar
Left front, right front, right rear, left rear is the order for a TPMS relearn if you have replaced the sensors (at least that is the order on my relearn tool). If you are just re-setting the system after adjusting the pressure up or down from the previous setting, you only need to press the re-set key in the glovebox.
Old Mar 4, 2013 | 12:06 AM
Thank you for the info. Very helpful.
cowboy
Jul 29, 2012 07:36 PM
EazyMack
Feb 7, 2010 10:00 PM
JTsyo
Dec 27, 2008 08:12 AM
SPBill
Oct 11, 2007 12:30 PM
Pravus Prime
Oct 11, 2005 03:14 PM
