For those in the midwest and northeast. How bad is you milage?
Old Feb 13, 2007 | 03:01 PM
  #31
TCHduped's Avatar
Default Re: For those in the midwest and northeast. How bad is you milage?
To expand on that further, try getting your engine warm to the level that it normally runs at. Then, turn it off and on again. Now, you can start a new trip with an already warm engine and look at the reading at the end of the trip.
Originally Posted by SPL
lizprius2006 — The colder weather has a very considerable effect on fuel consumption. This applies, of course, to all internal combustion gasoline engine vehicles, not just hybrids. I don't know whether this is what's causing your current bad fuel economy (FE) numbers, but before you conclude that there's something wrong with your Prius, I suggest that you conduct an experiment. Take a decent return trip of say at least 50 miles each way. Have the vehicle warmed up before you start. Look at your trip's FE figure. If it's closer to what you were getting before (it won't be quite as good because of the colder air temperatures), I'd conclude that there's nothing wrong. If not, perhaps you do indeed have a problem.
Stan
Old Feb 16, 2007 | 08:00 PM
  #32
TCHduped's Avatar
Default For those in the midwest and northeast. How bad is you milage?
Just drove 600+ miles today through NJ and upstate NY. Doing probably 76mph with cruise control and warm engine, averaged only 32 mpg.
Tires inflated at 34 psi , no snow on the ground or on my car, two passengers without too much cargo. Outside temperature was probably between 20-35 degrees.
Does this sound like crappy mileage or is it just me? I know it's cold, but these figures are with an already warm engine. When it was warmer, I was able to get 37 mpg on highway.
Old Feb 17, 2007 | 02:12 PM
  #33
SPL's Avatar
SPL
TCHduped — I think 76 mph is a bit too fast for good FE, summer or winter! Your 32 mpg equates to ~7.4 L/100 km, and that is comparable to what I'm getting at 120 km/h speeds on the highway in this cold weather.
Stan
Old Feb 17, 2007 | 06:16 PM
  #34
H2O Doctor's Avatar
Arrow Re: For those in the midwest and northeast. How bad is you milage?
A lot of factors go into FE. Weight is one of them. Most of my trips are to work when I drive alone. There is a noticeable decrease when I have a passenger or two.
Speed is another factor. If you are concerned about FE, drop your speed down to 70 mph. It makes a big difference.
I would also recommend a higher tire pressure. I have Michelins and run them at 40 psig.
Can't do anything about the temperature, except use ECO setting on your heater.
Curated Content Editor
Jul 1, 2014 03:10 PM
poscivic
Jun 13, 2012 06:38 PM
WScottCross
Sep 12, 2006 06:09 AM
dwmiller438
Feb 12, 2006 06:40 PM
jinno
Jul 2, 2004 06:04 AM
