Those 4 plastic plugs in glovebox???
Old Jun 7, 2007 | 10:57 AM
Ormond's Avatar
Default Re: Those 4 plastic plugs in glovebox???
I just checked my glovebox and sure enough the four plugs are there.
I hate to go to the dealership just for this.
Thanks for the useful information. Now I can justify my addiction to this forum!
Old Jun 7, 2007 | 02:48 PM
ymiheere's Avatar
Lightbulb Re: Those 4 plastic plugs in glovebox???
Originally Posted by schmidtj
I wonder why those wouldn't be installed at the factory.
Anyone care to speculate?
J
Hmmm.... great question! Maybe the words "torque box" are a clue? I'm guessing the dealer needs access to certain bolts in the frame prior to delivering the car, and then the holes should be plugged up!???!
Old Jun 7, 2007 | 02:54 PM
Pepsi's Avatar
The plugs are suppose to reduce road noise. The dealership told me the reason why they don't install them is because it causes water to pool. I didn't care enough to argue so I just tossed it back into the glovebox.
Old Jun 7, 2007 | 07:27 PM
JHSmith's Avatar
My response to "THE DEALERSHIP"
Let's see -- installing the plugs causes water to pool. Hmm . . . If the plug would block drainage holes, why would the Toyota engineers have supplied plugs to block-up these seep holes?
Second -- These plugs will close up four (4) holes that are on the underside of the car. Without the plugs installed, what will happen if you need to ford a stream or deep water where the water comes up that high? -- Hey, it happens. Wouldn't water get into the interior frame section of the car? And possibly pool there, allowing for the possibility of that area to rust-out from the inside? (I know, there is a rust protection warranty.)
Third -- Normally there is a "mark-up" listed as dealer prep, and this is listed under the Pre-Delivery Inspection. (You paid for it.)
poscivic
Jun 13, 2012 06:38 PM
dwichman
Aug 15, 2009 11:29 PM
mikecism
Apr 12, 2008 04:37 PM
jay_man2
Feb 10, 2008 06:04 PM
Resist
Oct 4, 2006 02:33 PM
