Is there a trick to removing the dash speaker grilles?
Old Apr 2, 2008 | 07:17 AM
spiff72's Avatar
Default Is there a trick to removing the dash speaker grilles?
I want to pull them out and put some felt on them where they seem to rub the windshield (and squeak), but I am not sure how to pull them out without damaging them.
Has anyone tried pulling them out?
Thanks!
Old Apr 2, 2008 | 08:34 AM
SPL's Avatar
SPL
Default Re: Is there a trick to removing the dash speaker grilles?
spiff72 — No, I haven't tried removing the tweeter grilles, but here's a document from the Repair Manual that indicates how they are held on.
Stan
File Type: pdf
Old Apr 2, 2008 | 08:37 AM
spiff72's Avatar
Stan
Sweet!
Thanks for that document, Stan. If I read it right, you need to disengage the hooks on the rear facing side first, and then lift and tilt forwards. I want to do this before it gets warm out, since the squeaks seem to improve in warmer weather.
Old Apr 2, 2008 | 09:03 AM
SPL's Avatar
SPL
spiff72 — My interpretation is basically similar to yours. First, release the 6 claws along the rearward (i.e., towards the rear of the car) and side edges of the grille (3 on each edge). Then tilt the grille upward at its rear edge — the 2 clips will release as you do this. Finally, lift the grille out towards the rear of the car.
Stan
Mr. Thyristor
Aug 28, 2009 01:30 AM
TCH80226
May 24, 2009 08:56 PM
fullofbeans
Dec 10, 2007 10:55 AM
sharpie
Honda Insight
Oct 8, 2007 08:14 AM
Lindenberg22
Aug 3, 2006 10:31 PM
