TCH Highway Mileage
Old Jan 26, 2008 | 04:41 PM
slatealtima's Avatar
Hybrid Enthusast
Default Re: TCH Highway Mileage
Originally Posted by flopshot
I think you should be able to get at least 40mpg, if not more, if the roads are really flat. I found that I get really great FE when traveling 65mph, but at 70mph the ICE tends to kick in more.
I don't understand what you mean by the ICE tends to kick in more. It's always on at highway speeds.
To the OP: Do it!
Old Jan 28, 2008 | 07:57 AM
chestr's Avatar
I believe when you're "coasting" at full speed, you're in "fuel-cut mode", where the ICE is spinning but not actually burning gas. I'm assuming the intended meaning is that at higher speeds it tends to fire up for acceleration purposes, dropping from the coasting mode where it says "60 mpg" on the instantaneous FE gauge, to 30s-40s or something.
It might be more clear with the NAV but yeah on the MFD it doesn't really give any sign you're not actually using gas at any time you're above say 43 mph.
mjh937
Honda Insight II
Jun 10, 2011 11:03 AM
prattman08
Dec 10, 2008 09:46 AM
CanonLaw
Nov 14, 2008 01:36 PM
Terence
28
Dec 7, 2006 12:27 PM
Orcrone
Jun 21, 2006 11:06 AM
