TCH 2008 Camry Hybrid Leak in AC Freon
Old Aug 30, 2019 | 09:04 PM
ausadbarc's Avatar
Red face TCH 2008 Camry Hybrid Leak in AC Freon
Hi!!
So I filled the AC upto around 38PSi and 3-4 days later it was down to 10psi.
This was a used car I bought and did not know about this while buying..
It's a 2008 TCH and not sure what is the best way to detect the leak.
Please suggest. It get's hot here in California sometimes..
Thanks!
Old Sep 6, 2019 | 04:31 PM
litespeed's Avatar
Professor Emeritus
Default Re: TCH 2008 Camry Hybrid Leak in AC Freon
You still should have it checked by a professional, but more than likely it's the evaporator. It is a common problem on all Camry's 2007 to 2011. They get a small leak and require replacement. When I had mine at the dealer getting it done a couple years ago, there were 3 other ones in there having the same thing done.
The bad news is that it costs about $1300 if you have the dealer do it for you like I did. But, if you are part of the dash replacement recall, you can have it done at the same time.
Edit: I did nurse mine along for about 1.5 years before it would not hold a charge for more than a couple days. I also had one of the cooling fans go bad and did not know it until this work was done. I replaced the cooling fan assembly on my own. And yes, it was a PITA.
rrmaron
Jun 22, 2021 05:09 PM
stonedat420
Aug 30, 2019 09:02 PM
Kev-FEH
Jul 8, 2013 06:12 AM
rangerhomer
Apr 5, 2007 03:12 PM
kenny
Jun 21, 2006 07:57 AM
