TCG Navigation v 6.1 hacks
Old Nov 7, 2007 | 06:17 AM
  #41
punkerg1's Avatar
Default Re: TCG Navigation v 6.1 hacks
Originally Posted by redwings7907
SUCCESS!! thanks so much to all of you for your savy. after three failed attempts, i finally made my hybrid nav dvd on my iMac G5 after downloading a program called dragon burn (reccomended by a co-worker) and taking advantage of the free trial version. i inserted the burned dvd into the nav, up popped the map with my current location. i tried the override, no luck. so i removed the fuse and reinserted it after a few minutes, i tried the override again, and volla.
Old Nov 7, 2007 | 05:27 PM
  #42
spam2000's Avatar
Ok, now we need to make up a v7.1 hack. *sigh* I need the 7.1 files.
Old Nov 12, 2007 | 07:38 PM
  #43
redwings7907's Avatar
does anyone know if this will work with 7.1? i have the 7.1 dvd and i swapped the loading kiwi file, but the dvd isn't recognized. i was successful with 6.1. could it be that i used a different name brand dl dvd?
Old Nov 13, 2007 | 12:14 AM
  #44
Dang's Avatar
Of course if you make a combo disk, the "I agree" button, which is gone in 7.1 will come back.
I actually think the speed pulse generator is probably a better solution. It should work with all future versions, and you won't be getting farther and farther behind in the OS.
Later!
Dang
Old Nov 13, 2007 | 02:45 PM
  #45
ag4ever's Avatar
Dazed and Confused
I have built the speed pulse generator, but have not been able to get it to work yet.
There is a person on tundrasolutions that has a TCH who got it to work. His post is in the tundra section as that is where this mod came from.
By just adding the switch to the speed sensor wire and disconnecting the sensor, you can buy yourself about 2 minutes of override time. This might be enough to fiddle with the nav, and if you need more time, just cycle the switch.
I still want the spg, so I don't have to cycle the switch to get more override time.
Old Dec 17, 2007 | 05:39 AM
  #46
TXVTX's Avatar
Looks like I won't be buying the v7.1 disc and really would really appreciate someone building me a v6.1 hacked disc as I'm not able to do so.
Old Dec 17, 2007 | 09:49 AM
  #47
mikieboyblue's Avatar
I sent you a PM Big Al.
Old Dec 17, 2007 | 11:39 AM
  #48
TXVTX's Avatar
Appreciate it.
Old Feb 22, 2008 | 04:37 PM
  #49
prestonljensen's Avatar
does anyone know where i can get a 5.1 or 6.1 disc? i just bought a 2008 scion xD. please let me know.
thanks,
prestonjensen
Old Apr 9, 2008 | 12:16 PM
  #50
coolshock1's Avatar
Driving in stealth mode
I have a set of lovely coasters that I am will to sell real cheap!!!!! I have tried 3 different programs and still can't get it right!!! Any suggestions. It's not like I really need it but would like the option. I don't like manufacturers making decisions for me. This is as bad a Verizon and their phones. Anyone willing to help a brother out??
