TCG Navigation v 6.1 hacks
Old May 5, 2007 | 05:58 PM
skata's Avatar
Default Re: TCG Navigation v 6.1 hacks
You only have to pull the fuse that is located in the hood area - just for a couple of minutes.
Old May 5, 2007 | 06:39 PM
titaniummd's Avatar
Is there anything that happens aside from having to reset the clock (ie reset the mileage of the trip computers,etc)? The nice thing is that the actual back up works except for the push-button hack (which I need to unplug the battery for).
I was just hesitant that it may interfere somehow with the Hybrid system/battery.
Old May 6, 2007 | 11:00 AM
skata's Avatar
It doesn't interfere with the Hybrid system. The only thing I had to do was restore user info from saved personal info and reselect radio stations.
Old May 6, 2007 | 05:09 PM
titaniummd's Avatar
Thanks for the reply. The angle at which to remove the lead was awkward. This sounds so stupid but: Do you take out the battery from the compartment and then loosen the nut? I didn't want to inadvertently loosen something.
Old May 7, 2007 | 04:43 AM
skata's Avatar
Don't disconnect the battery - just the fuse in the hood for about 5 minutes.
It is labled as Radio #1 and is located in the hood under the cover labled Relays/Fuses.
Old May 7, 2007 | 03:59 PM
titaniummd's Avatar
I am glad I asked. A doctor with a wrench is a dangerous sight.
Old May 7, 2007 | 06:18 PM
titaniummd's Avatar
I just went around the neighborhood to try it out. I got the service menu and I pushed the 'override' button but I still couldn't access the menus while driving. Now, I just tapped the button and even repeated it.
Do I have to hold the button down and wait for a sound or sign?
Old May 7, 2007 | 07:49 PM
jbollt's Avatar
You have to hold the override "button" until it beeps...
Old May 7, 2007 | 09:33 PM
stevenvillatoro's Avatar
Arrow Re: TCG Navigation v 6.1 hacks
Beep? I couldn't get my override button to beep, shriek, squeal, moan, groan, or wheeze... I just press it for about five seconds until it changes color.
Old May 7, 2007 | 09:41 PM
jbollt's Avatar
It changes color also...Steve..maybe you have the default beep setting turned off?
