Recommended engine air filter?
Old Mar 2, 2008 | 07:21 AM
skywagon's Avatar
Default Re: Recommended engine air filter?
Originally Posted by UWAdventurer
I have used K&N filters in all my vehicles for several years with no MAF sensor problems.
"97 dakota
'98 and '00 Durango
"05 Vibe ( which has the Toyota drivetrain)
K&N specifies that the oil on the filter will not harm the sensor, etc., and I have not had any problems.
Check the web site for more info
Sound like a know it alll engineer! Put whatever you want in there as it is your car. ROTFFLMAO!!!
Old Mar 11, 2008 | 01:26 PM
mikieboyblue's Avatar
Originally Posted by mikieboyblue
I have the TRD washable air filter. So far it seems to be working well. I am going to pull it out and check to see if there is dust after the filter.
Well I did not notice any dust on the inside of the air box or in the tube leading to the engine. Did a white glove test.
Of course this does not mean anything. The filter was very dirty and had bugs in it!!
I ended up replacing it with a Purolator. It seems like I lost some peppiness but this might just be psychological as all the reading I have done points to the fact that cotton gauze filters are only a little less restricting than "paper."
The last item I read was:
http://www.bobistheoilguy.com/airfilter/airtest1.htm
Mike
twolostminds
Nov 17, 2014 06:23 AM
dgyimao
Dec 31, 2009 09:38 AM
sanosteam
Dec 26, 2009 07:17 AM
bugs
May 26, 2009 12:05 AM
