Rear deck rattle fix instructions
Old Jan 22, 2013 | 08:28 AM
Ron AKA's Avatar
Default Re: Rear deck rattle fix instructions
Has anyone fixed a rattle/buzz sound that seems to come from the center of the dash? I have one that only acts up at freeway speeds on pavement that has a rough surface coat. You can't do much to trouble shoot where it is exactly coming from at that speed. Putting your hand on the cup holders, and A/C outlet vents seems to have no effect. It is not the hand hold on the roof. It basically seems to be something loose in the dash that only vibrates in this one situation. Annoying, and turning up the sound system is the only "fix" I have found.
Old Jan 22, 2013 | 06:32 PM
ukrkoz's Avatar
Very nice. Hope it stays that way for long, as I had soft foam strips packed in there before, and deck simply pops up off clips.
I am do the vent fix though, as I have sub in the trunk.
Great write up.
Old Aug 16, 2016 | 08:26 AM
Prince Mohiuddin's Avatar
Hi, I am new to this forum. I can not see the pictures in this post. If it is possible to fix the links or repost, will be extreamly helpful.
Old Apr 12, 2020 | 06:56 PM
Bo Henry's Avatar
Originally Posted by Squint
My car has remained quiet all week so I've documented my work. I tried to add/remove various types and methods of insulation in order to determine what worked and what didn't. I did not remove all my previous attempts at insulation so what I've done may not necessarily work in your vehicle. However, you should be able to use the instructions as a guide to accessing the components causing the noise and find your own solution.
Disclaimer: there is a chance that any of the plastic parts involved may break.
1. Fold down the rear seats.
2. Dig your fingers underneath the door trim to grab the front corner of each "roof side inner garnish." Pull the corner straight out towards the centerline of the car until clip one disengages. You should then be able to slide the garnish towards the front of the car and remove it. If not, I remembered incorrectly and clip 2 also needs to be disengaged before the garnish can be slid forward.
3. Place all your fingers under the "package tray trim assembly" (rear deck) and lift straight up to disengage front two clips. Then pull the assembly towards the front of the car to disengage the remaining two clips.
4. Place thin weatherstripping as shown:
The 3M double-sided foam mounting tape shown in some of the pictures probably doesn't do anything and is thus optional.
5. Replacing the rear deck assembly.
The two blue clips probably stayed behind when the rear deck assembly was removed. Locate them and pry them out. Then slide them into place on the bottom of the rear deck assembly:
Slide the rear deck assembly back into position. Press firmly in the areas above all 4 clips.
6. Roof garnish reinstallation.
Remove the clip in location 3 from the car body and install it in its mount on the inside of the garnish. Remove clips 1 & 2 from the garnish. Slide the garnish back into its original location, engaging clips 4 & 5 which remained attached to the car body. If both are engaged correctly, the rear half of the garnish will be secured. Place clips 1 & 2 in their mounts on the garnish then push the front end of the garnish straight in to secure it. Make sure the door trim is not getting in the way during any part of the procedure.
7. Hybrid battery vent rattle abatement.
The rear deck assembly does not have to be removed to perform this "fix."
Cut a strip of 3M double-sided foam mounting tape lengthwise and secure it as shown on both sides of the vent cover.
You can see where I previously placed two small bits of weatherstripping. The rattling did not go away completely after their addition so I don't think they're necessary.
can you repost the pictures they aren't showing up now
TCHooptey
Feb 7, 2012 05:38 PM
lkaufman
Feb 2, 2009 04:41 AM
Island Mariner
Feb 19, 2007 07:58 PM
jbollt
Feb 13, 2007 05:29 PM
jbollt
Nov 9, 2006 09:54 AM
